https://ausmini.com/forums/
Hinge pin / bush falling out drivers door
https://ausmini.com/forums/viewtopic.php?f=2&t=93469
Author:  jprior2912 [ Tue Aug 16, 2016 5:22 pm ]
Post subject:  Hinge pin / bush falling out drivers door
Hi everyone,
The door pin/bush that's in the top Hinge on my drivers door keeps dropping down after a few open and closes of the door (I then need to tap it back up with a hammer).
What's my best option for fixing this? Can you get oversized pins, or will I need a new Hinge, orrrr other suggestions?
James
Author:  drmini in aust [ Tue Aug 16, 2016 5:59 pm ]
Post subject:  Re: Hinge pin / bush falling out drivers door
jprior2912 wrote:
Hi everyone,
James
Find another hinge and repin it. Note the 4 hinges are different.
If the pin is falling out and it is right way up (knurl at top) the hinge hole is worn out.
Author:  9YaTaH [ Wed Aug 17, 2016 8:08 am ]
What the Doc said...or just drill, bush and re-pin the existing hinge...
Author:  Scoop [ Wed Aug 17, 2016 8:28 am ]
Would some form of Loctite product work on that?
Author:  drmini in aust [ Wed Aug 17, 2016 9:01 am ]
Sure, IF the holes in the top and bottom are not worn out. James should have shown me on Thursday. The knurl on top end of pin stops it falling out. But I have seen hinges fixed with nut and bolt, or even a broken hss drill bit. :(
Author:  John Smidt [ Wed Aug 17, 2016 6:12 pm ]
As Kevin said there are 4 different hinges & you cannot mix the hinge sections
or should I say you should not mix the hinge sections
the hinges are usually stamped UL, LL, UR, LR or they may be numbered
1 & 2 Together 3 & 4 together 5 & 6 together 7 & 8 together
