It is currently Mon Jul 28, 2025 1:30 am
PostPosted: Sun Aug 14, 2016 5:08 pm
Hi,
Is it possible to put a rear shock on a hydrolastic car? I am attempting to do so, but have run into a problem. I have changed the stub axle to accept the shock. The problem I have discovered is that it hits the hydrolastic bag and doesnt allow full sespension travel. Any ideas, orherwise I'll have to change the stub axle back to a spring one.
PostPosted: Sun Aug 14, 2016 5:29 pm
lol, don't even bother... you need to stop and understand what the spring does
the spring "simulates" extra weight at the rear of the car to compensate for the significantly heavier front-end, if you take it off, that weight is missing, so the car will just sit on it's nose
PostPosted: Sun Aug 14, 2016 6:22 pm
As per simon k,
The helper spring at the rear has an effect on the height at the front BECAUSE hydrolastic connects the front and rear - push down on the front guard and the rear will rise. Dry suspension does not connect a movement at the front wheel to the back wheel.
That is why fitting a shock absorber only at the front of a hydro car is enough to have a damping effect to front and rear.
