https://ausmini.com/forums/
Cone removal tool Newcastle
https://ausmini.com/forums/viewtopic.php?f=2&t=93438
Author:  bluehishouse [ Sun Aug 14, 2016 3:55 pm ]
Post subject:  Cone removal tool Newcastle
Ive read a bit about it and could knock one up but my time outside of work is pretty limited for shopping, so does anyone in newcastle have a cone compressor i could borrow? Payment in beer, weekend car work or love.
Nic
Sent from my SM-G900I using Tapatalk
Author:  TheMiniMan [ Mon Aug 15, 2016 2:16 pm ]
Post subject:  Re: Cone removal tool Newcastle
just remove the top control arm completely
you won`t need the spring-compressing tool
fit hi-lo adjuster struts back in & again , no need for compressing tool
re-new the control arm bearings & pin & seals while you`re there
check the 'seat" inside the top arm for the cone shaped seat that needs to still be cone-shaped for the new nylon cup to seat correctly
if you fit a new nylon cup into a worn arm it will distort quite quickly & you will have problems
Matt
Author:  oldblade [ Mon Aug 15, 2016 6:37 pm ]
How hard is it to remove the top arm? I'd like to replace all my bushes and rubbers in the front end and haven't attacked the suspension yet
Author:  bluehishouse [ Mon Aug 15, 2016 9:02 pm ]
not doing hi-lows and i was thinking of putting new cones in but wasn't sure. never had the suspension out so dunno what to expect, just don't want to get half the job done.
Author:  Phil 850 [ Mon Aug 15, 2016 9:22 pm ]
This is how I did it
viewtopic.php?f=2&t=91132
