https://ausmini.com/forums/
Speedo gear and pinion
https://ausmini.com/forums/viewtopic.php?f=2&t=93433
Author:  miniblue [ Sat Aug 13, 2016 6:24 pm ]
Post subject:  Speedo gear and pinion
I know this has been probably asked before but I have gone from a 3.76 diff to a 3.1
With 10" wheels and the motor is an aussie 998 is there a correct gear set available for this diff ratio ?
Author:  Matt I [ Sat Aug 13, 2016 9:33 pm ]
Post subject:  Re: Speedo gear and pinion
You need a 7/16 according to the Guessworks calculator (http://www.guess-works.com/Tech/ratio.htm) assuming a 1408 TPM speedo (850/deluxe/mini k).
Guessworks have the 16t as a new part, and usually have the 7t used, but this is shown as out of stock currently.
16t: http://www.guess-works.com/Shop/Parts/d ... htm?id=299
7t: http://www.guess-works.com/Shop/Parts/d ... htm?id=326
Author:  miniblue [ Mon Aug 15, 2016 7:58 am ]
Thanks Matt
It makes perfect sense.
