https://ausmini.com/forums/
Battery line
https://ausmini.com/forums/viewtopic.php?f=2&t=93428
Author:  ewatkins [ Sat Aug 13, 2016 1:00 pm ]
Post subject:  Battery line
Hey guys,
On a mini k am about to install a new battery line, are there any specifications that I need to be careful of? Or will any standard battery cable be fine?
Author:  drmini in aust [ Sat Aug 13, 2016 3:08 pm ]
Post subject:  Re: Battery line
Std cable is 4 gauge (110A continuous rating), about 25mm2 cross section. $8.90/M from roadtechmarine.com.au
I would replace with 2 gauge (160A continuous rating), about 35mm2 cross section.
Diameter total is 12mm, available in red or black. $14.95/M from roadtechmarine.com.au.
I have bought some for my son's Clubby resto. 3.5M will do the battery cable + starter cable.
You can also use 35mm2 welding cable.
[edit] God knows what current draw is on the Lucas starter. However a Gemini starter which is popular fitment on Minis, draws up to 350A according to its data sheet.
