It is currently Mon Jul 28, 2025 1:20 am
 Post subject: Battery line
PostPosted: Sat Aug 13, 2016 1:00 pm
Hey guys,
On a mini k am about to install a new battery line, are there any specifications that I need to be careful of? Or will any standard battery cable be fine?
 Post subject: Re: Battery line
PostPosted: Sat Aug 13, 2016 3:08 pm
Std cable is 4 gauge (110A continuous rating), about 25mm2 cross section. $8.90/M from roadtechmarine.com.au
I would replace with 2 gauge (160A continuous rating), about 35mm2 cross section.
Diameter total is 12mm, available in red or black. $14.95/M from roadtechmarine.com.au.
I have bought some for my son's Clubby resto. 3.5M will do the battery cable + starter cable.
You can also use 35mm2 welding cable.
[edit] God knows what current draw is on the Lucas starter. However a Gemini starter which is popular fitment on Minis, draws up to 350A according to its data sheet.
