Cooper Heater Mounts https://ausmini.com/forums/viewtopic.php?f=2&t=93423 |
Author: | IndigoBlueCooperS [ Fri Aug 12, 2016 7:53 pm ] |
Post subject: | Cooper Heater Mounts |
Are the Cooper / Mk1 S heater mounts on the inside fire wall the same as the Mk2 S or clubman? Are they pop riveted, welded or bolted in? Anyone have an original photo? |
Author: | oldblade [ Fri Aug 12, 2016 9:05 pm ] |
Post subject: | Re: Cooper Heater Mounts |
thats what mine looks like its a cooper s 1968 |
Author: | gtogreen1969 [ Fri Aug 12, 2016 9:58 pm ] |
The early cooper did not have the J brackets. They had a heat exchanger bolted up to the underside of the parcel shelf and the fan was under the bonnet. |
Author: | oldblade [ Fri Aug 12, 2016 10:02 pm ] |
Bugger mine must not be original |
Author: | drmini in aust [ Fri Aug 12, 2016 10:14 pm ] |
gtogreen1969 wrote: The cooper did not have the J brackets. They had a heat exchanger bolted up to the underside of the parcel shelf and the fan was under the bonnet. My mate had a later 997 Cooper, it had the brackets and heater. Car got written off and I put the heater into my 850. Edit pretty sure it was a 63/64 car. |
Author: | Bubbacluby [ Fri Aug 12, 2016 10:22 pm ] |
My mate has a late 998 Cooper (64ish I think) and it has the mk1 S heater unit |
Author: | gtogreen1969 [ Fri Aug 12, 2016 10:29 pm ] |
I just had a look at my Cooper photos and it looks like the under bonnet heaters were used on the CKD cars until around YKA2S1 2000. After that the cars were built here and had the J brackets. |
Author: | Goldbrocade_62 [ Sat Aug 13, 2016 5:50 am ] |
My 997 has the early style is below 2000 |
