It is currently Mon Jul 28, 2025 1:24 am
 Post subject: Hydro bags
PostPosted: Wed Aug 10, 2016 8:32 pm
Hi guys are there any issues with pumping the hydro system up with compressed air to test all connections ect, & what pressure. Cheers
 Post subject: Re: Hydro bags
PostPosted: Wed Aug 10, 2016 8:37 pm
I have done it in the past. The system takes 300psi so 110psi wont hurt it.
PostPosted: Thu Aug 11, 2016 10:12 am
Does that mean you have to take it all apart after the test to prefill the bags? Do the bags get filled prior to connecting? I have to do this too. Not sure how it works without bleed holes in the displacer to get air out.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Thu Aug 11, 2016 10:26 am
Ideally you would have the system evacuated with a vacuum pump before the final filling of fluid. However air can be bled off by raising the rear of the car then pumping and dumping a few times until the air has excaped.
PostPosted: Thu Aug 11, 2016 10:28 am
Mick explains it a bit here. viewtopic.php?t=59552
PostPosted: Thu Aug 11, 2016 10:36 am
Why raise the rear of the car; just pump it up high (4 fingers or so at front) then push the valve stem in hard to dump pressure as quick as possible. Repeat. Works for me...
[edit] I have a simple pump (clutch MC), it screws straight onto the hydro nipple. No fancy fittings...
PostPosted: Thu Aug 11, 2016 11:27 am
Its just something my mechanical brain tells me to do as air will go to the high spots. No real scientific evidence to it. Just makes me think i am doing it properly.
PostPosted: Thu Aug 11, 2016 7:50 pm
you're better off pumping it up with water to test for leaks..
PostPosted: Thu Aug 11, 2016 10:52 pm
Yeah me too. BMC should have put the connections at top of the front subframe, as on the Morris 1100. Which came out before the hydro Mini, go figure... :?
Users browsing this forum: No registered users and 119 guests
