It is currently Sat Jul 26, 2025 9:54 pm
 Post subject: Cooper Heater Mounts
PostPosted: Fri Aug 12, 2016 7:53 pm
Are the Cooper / Mk1 S heater mounts on the inside fire wall the same as the Mk2 S or clubman?
Are they pop riveted, welded or bolted in?
Anyone have an original photo?
 Post subject: Re: Cooper Heater Mounts
PostPosted: Fri Aug 12, 2016 8:48 pm
The heater J brackets were spot welded on. I believe the mounting position was the same for all the heaters except for the late 1970 beehive heater. They used 3 captive nuts.
PostPosted: Fri Aug 12, 2016 9:05 pm
thats what mine looks like its a cooper s 1968
1968 Morris Mini Cooper S
PostPosted: Fri Aug 12, 2016 9:58 pm
The early cooper did not have the J brackets. They had a heat exchanger bolted up to the underside of the parcel shelf and the fan was under the bonnet.
PostPosted: Fri Aug 12, 2016 10:02 pm
Bugger mine must not be original
PostPosted: Fri Aug 12, 2016 10:14 pm
gtogreen1969 wrote:
The cooper did not have the J brackets. They had a heat exchanger bolted up to the underside of the parcel shelf and the fan was under the bonnet.
My mate had a later 997 Cooper, it had the brackets and heater. Car got written off and I put the heater into my 850.
Edit pretty sure it was a 63/64 car.
Last edited by drmini in aust on Fri Aug 12, 2016 10:24 pm, edited 1 time in total.
PostPosted: Fri Aug 12, 2016 10:19 pm
No yours is original for the Cooper S 1965 - 1969
This is the Cooper type they used before going to the Cooper S style. I don't know when the change over occurred.
PostPosted: Fri Aug 12, 2016 10:22 pm
My mate has a late 998 Cooper (64ish I think) and it has the mk1 S heater unit
PostPosted: Fri Aug 12, 2016 10:29 pm
I just had a look at my Cooper photos and it looks like the under bonnet heaters were used on the CKD cars until around YKA2S1 2000. After that the cars were built here and had the J brackets.
PostPosted: Sat Aug 13, 2016 5:50 am
My 997 has the early style is below 2000
