9YaTaH wrote:
Lillee wrote:
Anchor point isn't the most crucial point in a crash? Can't find any engineering info using google.
Genuine question, I'm not trying to raise any arguments.
Answered your own question I think...anchor points not crucial
No...anchor points are highly crucial
OP is referring to the single top anchor point that the baby seat secures onto, not the seatbelt anchor points
I can't see how this single top middle anchor point that holds the seat in is "highly crucial" when the seat belt holds the person in using a booster where the child is using the car seat belt.
OK I can see if using a child capsule or reclining seat that has it's own belts, this might be a problem, in which case it is probably advisable to get the parcel shelf completely strengthened or possibly it may not even advised to use anything other than a booster style seat
EDIT: Let me rephrase: If you are planning to put in anything other than a booster style child seat where the child is using the car's seat belts, you will need to heavily modify the parcel shelf of your mini to put in a strong anchor point. The mini parcel shelf is weak. If using a booster style seat then top anchor point isn't what is holding the kid in.
Case in point:
I'm done with this topic
