It is currently Mon Jul 28, 2025 4:06 am
 Post subject: Speedo gear and pinion
PostPosted: Sat Aug 13, 2016 6:24 pm
I know this has been probably asked before but I have gone from a 3.76 diff to a 3.1
With 10" wheels and the motor is an aussie 998 is there a correct gear set available for this diff ratio ?
Did i tell you that all my minis are 850's ?
PostPosted: Sat Aug 13, 2016 9:33 pm
You need a 7/16 according to the Guessworks calculator (http://www.guess-works.com/Tech/ratio.htm) assuming a 1408 TPM speedo (850/deluxe/mini k).
Guessworks have the 16t as a new part, and usually have the 7t used, but this is shown as out of stock currently.
16t: http://www.guess-works.com/Shop/Parts/d ... htm?id=299
7t: http://www.guess-works.com/Shop/Parts/d ... htm?id=326
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Aug 15, 2016 7:58 am
Thanks Matt
It makes perfect sense.
