Timing light https://ausmini.com/forums/viewtopic.php?f=2&t=93344 |
Author: | oldblade [ Wed Aug 03, 2016 9:20 pm ] |
Post subject: | Timing light |
So I bought one of these http://www.ebay.com.au/itm/252041063324 ... EBIDX%3AIT but for the life of me I can't find the timing marks ![]() ![]() |
Author: | gtogreen1969 [ Wed Aug 03, 2016 9:58 pm ] |
Post subject: | Re: Timing light |
You need to go through an inspection hole above the clutch cover. http://www.ausmini.com/manuals/Mini%20W ... System.pdf That is a good timing light. I have the same one. |
Author: | oldblade [ Wed Aug 03, 2016 10:02 pm ] |
OK so I aim the light in there ? |
Author: | gtogreen1969 [ Wed Aug 03, 2016 10:08 pm ] |
Yes but there is not much room with the booster in the way. Some mini places sell a mirror that attaches to the opening. I would find TDC first by taking out the No1 spark plug and placing a long straw or stick in the hole then with the car in gear rock it forward until it reaches its highest point. Then get a torch and have a really good look at the marks on the flywheel. Mark the TDC with some white paint or white out. |
Author: | oldblade [ Wed Aug 03, 2016 10:15 pm ] |
thank you I'll have another go at it |
Author: | TheMiniMan [ Thu Aug 04, 2016 11:56 am ] |
a mirror is your friend with this one ![]() |
Author: | timmy201 [ Thu Aug 04, 2016 12:11 pm ] |
There is a pre-made mirror you can buy. I found the timing mark, and then made a pointer and mark on the crank pulley to make it a bit easier. You only need TDC marked with a dialback timing light like the one you've bought. http://www.minisplus.com.au/classic-min ... sing-cover |
