It is currently Mon Jul 28, 2025 1:18 am
 Post subject: Timing light
PostPosted: Wed Aug 03, 2016 9:20 pm
So I bought one of these
http://www.ebay.com.au/itm/252041063324 ... EBIDX%3AIT
but for the life of me I can't find the timing marks :oops: :oops:
1968 Morris Mini Cooper S
 Post subject: Re: Timing light
PostPosted: Wed Aug 03, 2016 9:58 pm
You need to go through an inspection hole above the clutch cover.
http://www.ausmini.com/manuals/Mini%20W ... System.pdf
That is a good timing light. I have the same one.
PostPosted: Wed Aug 03, 2016 10:02 pm
OK so I aim the light in there ?
PostPosted: Wed Aug 03, 2016 10:08 pm
Yes but there is not much room with the booster in the way. Some mini places sell a mirror that attaches to the opening.
I would find TDC first by taking out the No1 spark plug and placing a long straw or stick in the hole then with the car in gear rock it forward until it reaches its highest point. Then get a torch and have a really good look at the marks on the flywheel. Mark the TDC with some white paint or white out.
PostPosted: Wed Aug 03, 2016 10:15 pm
thank you I'll have another go at it
PostPosted: Thu Aug 04, 2016 11:56 am
a mirror is your friend with this one :-)
PostPosted: Thu Aug 04, 2016 12:11 pm
There is a pre-made mirror you can buy. I found the timing mark, and then made a pointer and mark on the crank pulley to make it a bit easier. You only need TDC marked with a dialback timing light like the one you've bought.
http://www.minisplus.com.au/classic-min ... sing-cover
