It is currently Mon Jul 28, 2025 3:09 am
 Post subject: mesh light covers
PostPosted: Tue Aug 02, 2016 9:13 pm
Has anyone ever installed these http://minikingdomonline.com.au/product ... sh-guards/
I am very confused :roll:
1968 Morris Mini Cooper S
 Post subject: Re: mesh light covers
PostPosted: Wed Aug 03, 2016 7:29 am
I have. Three clips per side are screwed in to the headlight retaining ring. I bent the clips a little to hold the mesh on better
PostPosted: Wed Aug 03, 2016 9:58 am
I've had them on my clubby for years with no broken glass to date. The above pic from timmy201 shows fitment.
If you angle them slightly you can get a subtle angry-eyes look, or sad if you go the other way. :)
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Wed Aug 03, 2016 10:18 am
Thanks ill have a go again tonight
PostPosted: Wed Aug 03, 2016 2:50 pm
I prefer the mesh guard that sits under the headlight ring without clips
are the ones you are describing the actual mini ones though?
PostPosted: Wed Aug 03, 2016 2:55 pm
Oldblade I have the ones that sit under the headlight rim willing to sell you a set.
PostPosted: Wed Aug 03, 2016 3:01 pm
I had trouble fitting them up to my Clubman when attempting to fit them as timmy has. they would not fit behind the headlight surrounds/grill, even when i cut the clips down to pull the covers further back to the headlight. I ended up attaching them to the headlight surrounds and it still looks pretty good
PostPosted: Wed Aug 03, 2016 3:28 pm
I have this type... one time I had a filament go so replaced the light with a newie, then I looked at the difference between the new light and the old light on the other side and OH MY GOD THERE WAS A LOT OF CRAP ON THE LIGHT!!! the mesh makes it pretty hard to clean the headlights :lol:
PostPosted: Wed Aug 03, 2016 4:02 pm
I have already bought them it was one of those "that might look nice" purchases. After trying to fit them they may end up on the garage wall[SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
PostPosted: Wed Aug 03, 2016 4:34 pm
I did some modification of the clips with some needle nose pliers to get them to stay on better.
PostPosted: Wed Aug 03, 2016 4:52 pm
Thanks
