Clubman heater tap https://ausmini.com/forums/viewtopic.php?f=2&t=93321 |
Author: | waznotme [ Mon Aug 01, 2016 9:27 pm ] |
Post subject: | Clubman heater tap |
Hi all, I'm trying to get my 77' clubman heater to work and the tap has seized which seems to be fairly common, what's everyone doing to fix this or what heater taps are people using? I've noticed that a xy falcon heater tap is very close and cheaper. |
Author: | Hobson [ Mon Aug 01, 2016 10:33 pm ] |
Post subject: | Re: Clubman heater tap |
viewtopic.php?f=25&t=44289 |
Author: | shnitzee [ Tue Aug 02, 2016 12:02 am ] |
I used the 'Heater tap fix' instructions in the forum's 'How To' section. Eiles |
Author: | waznotme [ Tue Aug 02, 2016 7:50 am ] |
Thanks I'll check it out. |
Author: | 78Clubbie [ Tue Aug 02, 2016 8:22 am ] |
Mini kingdom stock the correct heater tap (Although you need to swap around handing on the slide). I just changed mine out |
