It is currently Mon Jul 28, 2025 1:19 am
 Post subject: Clubman heater tap
PostPosted: Mon Aug 01, 2016 9:27 pm
Hi all, I'm trying to get my 77' clubman heater to work and the tap has seized which seems to be fairly common, what's everyone doing to fix this or what heater taps are people using?
I've noticed that a xy falcon heater tap is very close and cheaper.
 Post subject: Re: Clubman heater tap
PostPosted: Mon Aug 01, 2016 10:33 pm
viewtopic.php?f=25&t=44289
Nick
PostPosted: Tue Aug 02, 2016 12:02 am
I used the 'Heater tap fix' instructions in the forum's 'How To' section.
Eiles
PostPosted: Tue Aug 02, 2016 7:50 am
Thanks I'll check it out.
PostPosted: Tue Aug 02, 2016 8:22 am
Mini kingdom stock the correct heater tap (Although you need to swap around handing on the slide). I just changed mine out
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
