https://ausmini.com/forums/
rust convertor to use
https://ausmini.com/forums/viewtopic.php?f=2&t=93319
Author:  71morris [ Mon Aug 01, 2016 6:55 pm ]
Post subject:  rust convertor to use
rust converter on car panels that people have used
Author:  71morris [ Mon Aug 01, 2016 7:00 pm ]
best results or any to avoid
Author:  M-JAY [ Mon Aug 01, 2016 7:45 pm ]
Post subject:  Re: rust convertor to use
The best way is to get rid of the rust. Use this in your angle grinder. https://www.bunnings.com.au/josco-100mm ... h_p6326672
I have used them for years they are brilliant. If you use any other type of wire brush they won't be as good. I've used most and these are brilliant almost evil. You won't be disappointed. Please use glasses or full face shield because they will spit wire. Once you've removed the paint and rust use either Protec 971 bare metal conditioner or Deoxdine. I use Protec 971 because my local auto paint place stocks it. Deoxdine is a brand name version. They contain phosphoric acid and will clean any remaining rust left. Just dilute as per instructions or use neat for super great results. Then rub into the surface with course wire wool. Yes it's acid so use nitrile gloves don't panic it's not that bad. Then paint as normal. It is worth chasing down either of these products because they are good. Getting rid of rust isn't hard, even the thickest and worse rust can be removed using this process. First mechanical removal then chemical removal.
Author:  71morris [ Mon Aug 01, 2016 7:57 pm ]
what about septone
or any other known brands
need to possibly treat an area to paint
Author:  captainwaldopepper [ Mon Aug 01, 2016 8:04 pm ]
I use a wire wheel and diluted Phosphoric Acid-works a treat!
+1 for Josco twisted wire wheels :D
Author:  71morris [ Mon Aug 01, 2016 8:14 pm ]
already through the paint,
it is a rust patch
just wanted to know what treatment brands people are are using
Author:  M-JAY [ Mon Aug 01, 2016 8:53 pm ]
71morris wrote:
what about septone
Sorry never used Sepetone. Deoxdine and Protec 971 are considered professional products and are generally not available from high street stores. Sepetone rust converter seems expensive compared to what you pay for Protec. I think I paid $20ish for a litre bottle and it did a complete restoration and odd paint work jobs for years afterwards. Look for your local trade auto paint supplier they are a wealth of information and can supply stuff that Supercheap have never heard of. Both of these products are phosphoric acid based bare metal conditioning products.
Author:  71morris [ Tue Aug 02, 2016 2:17 pm ]
thanks for the info will have a look on the internet for it also
Author:  DavidE [ Tue Aug 02, 2016 2:27 pm ]
Although it's probably not the stuff that can come through the postal system.
Author:  71morris [ Tue Aug 02, 2016 3:03 pm ]
Found a brand in Queensland, who can post
but I have not heard of the brand
