Ignition light staying on https://ausmini.com/forums/viewtopic.php?f=2&t=93285 |
Author: | ricksmini [ Thu Jul 28, 2016 9:05 pm ] |
Post subject: | Ignition light staying on |
Hi all just got the car running today but my ignition light stays on while it's running what could the problem be? |
Author: | Stev0 [ Thu Jul 28, 2016 9:22 pm ] |
Post subject: | Re: Ignition light staying on |
It's not charging. Thats what the light is there to tell you! |
Author: | ricksmini [ Thu Jul 28, 2016 9:39 pm ] |
It's a new alternator and battery |
Author: | Lillee [ Thu Jul 28, 2016 9:55 pm ] |
Wrong/loose wiring? Run a multimeter across the battery terminal while it's running, that will tell you straight away if alternator is working or not. |
Author: | Convertible Mini [ Fri Jul 29, 2016 2:55 am ] |
Does the ignition light come one when Key is turned on and stays on after engine is started and running or Light comes on only after engine is started? |
Author: | ricksmini [ Fri Jul 29, 2016 6:22 am ] |
Convertible mini it comes on and stays on when engine is running. |
Author: | simon k [ Fri Jul 29, 2016 2:37 pm ] |
ricksmini wrote: Convertible mini it comes on and stays on when engine is running. your new alternator isn't alternating like it's meant to... |
Author: | 1071 S [ Fri Jul 29, 2016 5:36 pm ] |
...... because its not connected properly??? Cheers, Ian |
