It is currently Mon Jul 28, 2025 6:26 am
PostPosted: Sat Jul 16, 2016 3:20 pm
Hi all
I want to use one of my spare Contessas as the spare for the mini so just want to make sure it's safe to use.
Is this one okay? If not is it repairable?
Any advice is appreciated.
:D
Eiles
PostPosted: Sat Jul 16, 2016 3:29 pm
As long as it has the tapered washers in the outside, it will be fine. Unless there are cracks i can't see.
PostPosted: Sat Jul 16, 2016 3:36 pm
Thanks drmini, that's good to know.
PostPosted: Sun Jul 17, 2016 2:56 pm
Check the spokes for cracks, usually easier to see from the back. I had a wheel years ago which developed cracks after a heavy hit with a kerb.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jul 17, 2016 7:00 pm
Put on the wall of your Man Cave as a curiosity! :idea:
PostPosted: Sun Jul 17, 2016 8:21 pm
I've got three others so I'll have a good look and use the best one of the lot.
Thanks for the advice fellas.
Eiles
PostPosted: Mon Jul 18, 2016 3:05 pm
i work on the theory that if i need to ask the question, then the answer is no.
