Is this Contessa safe to use https://ausmini.com/forums/viewtopic.php?f=2&t=93155 |
Author: | drmini in aust [ Sat Jul 16, 2016 3:29 pm ] |
Post subject: | Re: Is this Contessa safe to use |
As long as it has the tapered washers in the outside, it will be fine. Unless there are cracks i can't see. |
Author: | shnitzee [ Sat Jul 16, 2016 3:36 pm ] |
Thanks drmini, that's good to know. Cheers |
Author: | michaelb [ Sun Jul 17, 2016 2:56 pm ] |
Check the spokes for cracks, usually easier to see from the back. I had a wheel years ago which developed cracks after a heavy hit with a kerb. |
Author: | 9YaTaH [ Sun Jul 17, 2016 7:00 pm ] |
Put on the wall of your Man Cave as a curiosity! ![]() |
Author: | shnitzee [ Sun Jul 17, 2016 8:21 pm ] |
I've got three others so I'll have a good look and use the best one of the lot. Thanks for the advice fellas. Eiles |
Author: | greyghost [ Mon Jul 18, 2016 3:05 pm ] |
i work on the theory that if i need to ask the question, then the answer is no. |
