https://ausmini.com/forums/
Chrome side moulding
https://ausmini.com/forums/viewtopic.php?f=2&t=93134
Page 1 of 2
Author:  Minicooper4me [ Wed Jul 13, 2016 9:12 pm ]
Post subject:  Chrome side moulding
I have just installed chrome side mouldings on my 66 Deluxe. They came up a treat by utilizing a hair dryer on the 2 tight bends. Overall they are a tight fit but I'm guessing a speed they would work their way loose. Are there clips available to hold them on or do I install pop rivets on the underside, or are there any other tricks to keep them retained. Thanks.
Author:  DOZ [ Wed Jul 13, 2016 9:45 pm ]
Post subject:  Re: Chrome side moulding
Rivets will damage the trim, use trim clips ala
Author:  Minicooper4me [ Wed Jul 13, 2016 9:53 pm ]
Thanks DOZ. Are they the door rubber trim clips for wind up windows.
Author:  DOZ [ Wed Jul 13, 2016 10:01 pm ]
no idea. Mine were held on with rivets in 4 spots on each side (either side of the wheel arches). I've seen these trim clips used on other cars.
Maybe someone else can tell us both as I will be putting new ones on for Bathurst
Author:  gtogreen1969 [ Wed Jul 13, 2016 10:56 pm ]
My MK1 S has the moulded side strips and they are only pushed on. However I put a set of the standard side strips on my Clubby last year and it needed a rivet at the front and back. I haven't tried any type of clip.
Author:  Babes [ Thu Jul 14, 2016 1:09 am ]
I put these on the other night, http://minisport.com.au/chrome-plastic- ... of-the-car
Took less than 5 mins each side, no clips or rivets or heat and it was cold about 10c. Couldn't believe how easy it went on.
Author:  Hobson [ Thu Jul 14, 2016 9:20 am ]
When talking to John S, he suggests nothing at first, then clips, then if all else fails rivets.
speaking of which i need to redo mine.
Author:  Minicooper4me [ Thu Jul 14, 2016 11:27 am ]
Thanks guys. I have a few of those clips that DOZ suggested. I have a bit of time on my hands before she hits the road. Will wait till then and allow for any stretching then put a few on. I think one at each end, one at each end on the straight bit before the bends, nothing on the wheel arches.
Author:  winabbey [ Thu Jul 14, 2016 4:51 pm ]
If you need more clips NOS ones are quite inexpensive.
http://minikingdomonline.com.au/product ... g-kit-nos/
Author:  Bill B [ Thu Jul 14, 2016 7:36 pm ]
I have used S style plastichrome mould on my mini K without flares - no clips or pop-rivets - just sits in place. It's a bit harder when fitting to plastic flares.
By the way, the factory accessory flare kits came with the same trim clips used on the vertical seam covers - a simple U-section with barbs on both sides. I have never used them so don't know how well they worked as most of the moulds grip without any extra help.
Author:  Minicooper4me [ Thu Jul 14, 2016 9:32 pm ]
Thanks for the info guys. Much appreciated.
Author:  HistoricRacingS [ Tue Aug 02, 2016 10:47 pm ]
We glue them on the race car as they come loose at speed.
Contact adhesive and then push them on.
Author:  slacko [ Wed Aug 03, 2016 8:45 pm ]
the vertical seam cover clips are not the same as the ones for the cooper s side moulds
if you look at the two , you will see that the side mould clip has a angled raised edge on one side only
this edge hooks behind the top edge of the side mould , the under side is flat other than the barbs that lock onto the metal lip
When my cooper s moulds where put on , there where no clips and no rivets
over time as the mould shrunk , expanded and hardend to the shape of the car edge they became loose
this is when I put clips in , and only where the mould was very loose on the seams
I found it better to pull the mould back slightly , put the clip in the mould , not on the seam , and push it back on the seam
Over a 4 year period I would probably have put on a total of 12 clips. and not on the tight bends neither
just my 2 bobs worth
Mark
Author:  Minicooper4me [ Wed Aug 03, 2016 9:55 pm ]
Good info slacko, much appreciated.
Author:  winabbey [ Fri Apr 20, 2018 11:42 am ]
In case it's of interest here's what the factory advised on fitting the earlier flat side moulding. Probably the same for the Cooper S style.
