https://ausmini.com/forums/
Rubber cones
https://ausmini.com/forums/viewtopic.php?f=2&t=93050
Author:  ricksmini [ Sun Jul 03, 2016 6:49 pm ]
Post subject:  Rubber cones
Hi all how do you keep the rubber cones in place? When I jack the car up they always fall out of place. They are in a wet subframe is that the problem? The cones and shocks are brand new. Do I need shorter shocks?
Author:  miniman269 [ Mon Jul 04, 2016 3:22 pm ]
Post subject:  Re: Rubber cones
Yep
Sent from my SM-G900I using Tapatalk
Author:  TheMiniMan [ Mon Jul 04, 2016 6:12 pm ]
we fit the std Hydro rear ext rod bacxk in (the type with the spring inside)
that way , no matter how low you set your suspension ride-height, the whole lot stays in place
however, Most mini shops sell the "after-Market" type rear ext rods, with no sprung pin
so any lowering (or fitting into hydro frames/arms) the cone can fall out & jam & such
Author:  ricksmini [ Mon Jul 04, 2016 9:23 pm ]
Mini man do you have a photo of the rear extension rods? Do they fit the front aswell
Author:  Minicooper4me [ Mon Jul 04, 2016 9:27 pm ]
I'm not familiar with these rear ext rod thingys. Dies anyone have a picture please as I have the same problem if the hi los are set too low.
Author:  Minicooper4me [ Fri Jul 08, 2016 10:21 pm ]
Is there anyone out there who is familiar with these thingys. Much appreciated.
Author:  gtogreen1969 [ Fri Jul 08, 2016 10:59 pm ]
Item 20. 4G7809 and Item 21. 21A1704
Author:  Minicooper4me [ Sun Jul 10, 2016 10:02 pm ]
Thanks gtogreen. I understand how this works for hydro suspension, but how can these be fitted to dry suspension cones and work. I must be on the wrong track or train of thought.
Author:  gtogreen1969 [ Sun Jul 10, 2016 11:52 pm ]
You use them with HiLos instead of the trumpets. But no one else has mentioned HiLos so maybe I am on the wrong track.
Author:  Minicooper4me [ Mon Jul 11, 2016 5:19 pm ]
Yep, I'm on hilos. So how does these thingys hook up to hilos and cones ?
