https://ausmini.com/forums/
A+ Camshaft
https://ausmini.com/forums/viewtopic.php?f=2&t=93040
Author:  bluewhitecoopers1968 [ Sun Jul 03, 2016 12:59 am ]
Post subject:  A+ Camshaft
Hi all, just a quick question, can an A+ Camshaft be used in an A series engine. Cheers.
Sent from my SM-G900I using Tapatalk
Author:  drmini in aust [ Sun Jul 03, 2016 7:34 am ]
Post subject:  Re: A+ Camshaft
Yes no problem, use with 1275A+ slot drive oil pump.
Use 998A+ pump for small bore motors.
Author:  bluewhitecoopers1968 [ Mon Jul 11, 2016 1:33 am ]
Is the dizzy gear on the A+ cam the same as the A Kevin, Guy here in the UK says there not interchangeable. He has a few std A plus wide lobe cams for 15 pounds each. Cheers
Author:  drmini in aust [ Mon Jul 11, 2016 6:41 am ]
Drive gear on cam is the same.
I recently put an A+ cam in a 998 A series, no problem. GR reground it to an RE266SS.
I think all A+ cams are wide lobe/slot drive? Anyhow this one was.
[edit] 15 quid is cheap, all wide lobe stock cams are getting scarce in Oz now. Bring a few in, they'll sell easy. :mrgreen:
Author:  bluewhitecoopers1968 [ Mon Jul 11, 2016 7:10 pm ]
Cheers Doc, I'll do that. Richard.
Author:  goodie [ Sun Sep 04, 2016 6:18 pm ]
What are the benefits of running a wide lobe cam in a small bore engine, if any ?
Author:  drmini in aust [ Sun Sep 04, 2016 6:21 pm ]
Probably a little less cam lobe wear.
