Importing motors any issues? https://ausmini.com/forums/viewtopic.php?f=2&t=93010 |
Author: | mattywood [ Wed Jun 29, 2016 10:34 pm ] |
Post subject: | Importing motors any issues? |
Has anyone imported any engines from the uk? Was there anyway to check the engine is not nicked or issues getting it regoed in oz? |
Author: | Harley [ Thu Jun 30, 2016 12:42 pm ] |
Post subject: | Re: Importing motors any issues? |
Only drama I'm aware of locally is some UK engines have the numbers riveted on, not stamped. Gotta be stamped to the block for use out here. |
Author: | mattywood [ Thu Jun 30, 2016 1:02 pm ] |
I think I can sort that. |
Author: | poeee [ Thu Jun 30, 2016 1:06 pm ] |
Harley wrote: Only drama I'm aware of locally is some UK engines have the numbers riveted on, not stamped. Gotta be stamped to the block for use out here. Does one stamp the number on themselves, or does vicroads (or appropriate state authority) need to issue you a new number? |
Author: | simon k [ Thu Jun 30, 2016 5:25 pm ] |
poeee wrote: Harley wrote: Only drama I'm aware of locally is some UK engines have the numbers riveted on, not stamped. Gotta be stamped to the block for use out here. Does one stamp the number on themselves, or does vicroads (or appropriate state authority) need to issue you a new number? one is best to not ask... if one asks, then one is required to have the appropriate state authority issue a number |
Author: | 1071 S [ Thu Jun 30, 2016 6:27 pm ] |
Well that's the way BMC did it when they were building new cars.... I seem to remember I had to get a Blue Slip (it was 25 years ago) and show a receipt for the purchase of the engine. Once I had those, the RTA changed the numbers on the rego certificate. Cheers, Ian |
Author: | Mokesta [ Thu Jun 30, 2016 8:03 pm ] |
Meh, nobody cares. My car has an MG Metro engine in it that still has the riveted on plate. Sailed through rego. |
Author: | mattywood [ Thu Jun 30, 2016 8:46 pm ] |
And there is enough a+ here not to worry I suppose. |
Author: | miniman269 [ Fri Jul 01, 2016 8:41 am ] |
I had an engine that had a plate riveted to the block...I didnt need anything special..My original blew up I just went to main roads and gave them the new engine number she changed it there and then no problems Sent from my SM-G900I using Tapatalk |
Author: | Hobson [ Fri Jul 01, 2016 11:28 am ] |
They don't really care about the engine number to much, as long as it is the "Correct" engine for the car and that it has a number. |
Author: | Timbo [ Fri Jul 01, 2016 4:21 pm ] |
Plenty of personal import Minis still have their aluminium plate. Tim |
Author: | Convertible Mini [ Sun Jul 03, 2016 10:03 am ] |
V6 Volvo had a little Aluminium plate with engine number on the side of the block too. They were never refused Rego. It is quite a common practice. |
Author: | Goldbrocade_62 [ Sun Jul 03, 2016 10:33 am ] |
Tell them nothing just let them pick it if they notice it |
