Changing polarity of Generator https://ausmini.com/forums/viewtopic.php?f=2&t=92976 |
Author: | Bubbacluby [ Sat Jun 25, 2016 7:04 pm ] |
Post subject: | Changing polarity of Generator |
Changing back to a generator on my moke and am unsure if the polarity of the generator has been changed to negative earth. How to ensure it is negative earth if someone who owned the generator before me didn't do it? Thanks |
Author: | Goldbrocade_62 [ Sat Jun 25, 2016 7:07 pm ] |
Post subject: | Re: Changing polarity of Generator |
Just re-do it to be safe |
Author: | 9YaTaH [ Sat Jun 25, 2016 7:11 pm ] |
Author: | TheMiniMan [ Sat Jun 25, 2016 7:15 pm ] |
if its a std issue Lucas mini generator then all you need to do is hook up the battery (Neg earth or pos earth) depending on what you want make sure your coil is wired to suit also then turn the ign key on & it will automatically Pole itself start the car & test output charge with multi-meter to confirm all is well |
Author: | Bubbacluby [ Sat Jun 25, 2016 8:04 pm ] |
Thanks Matt So does it all by itself. All I wanted to know Thankyou |
Author: | Curly [ Sat Jun 25, 2016 8:45 pm ] |
....... and change the wires around on the heater fan too, otherwise it will try to suck air out of the cabin ![]() |
Author: | Bubbacluby [ Sat Jun 25, 2016 9:11 pm ] |
Curly wrote: ....... and change the wires around on the heater fan too, otherwise it will try to suck air out of the cabin ![]() It has no heater, I was originally running a generator and it kicked it while on holidays so had get an alternator wired up, and that has recently kicked it in, so going back to generator. |
Author: | gtogreen1969 [ Sat Jun 25, 2016 11:26 pm ] |
Bubbacluby wrote: Curly wrote: ....... and change the wires around on the heater fan too, otherwise it will try to suck air out of the cabin ![]() It has no heater, I was originally running a generator and it kicked it while on holidays so had get an alternator wired up, and that has recently kicked it in, so going back to generator. Don't forget to oil it. ![]() |
Author: | Bubbacluby [ Sun Jun 26, 2016 12:19 am ] |
gtogreen1969 wrote: Bubbacluby wrote: Curly wrote: ....... and change the wires around on the heater fan too, otherwise it will try to suck air out of the cabin ![]() It has no heater, I was originally running a generator and it kicked it while on holidays so had get an alternator wired up, and that has recently kicked it in, so going back to generator. Don't forget to oil it. ![]() Hahaha.. someone remembered. |
Author: | RNY997 [ Mon Jun 27, 2016 12:47 pm ] |
Bubbacluby wrote: Thanks Matt So does it all by itself. All I wanted to know Thankyou field terminal is "flashed" to earth after reversing the battery terminals using a wire from the +ve terminal is the correct method. |
Author: | Convertible Mini [ Mon Jun 27, 2016 5:19 pm ] |
I wouldn't take anything for granted. you run the risk of ruining the Voltage regulator or cutout points. It takes two seconds to just ark between the F wire and the B+ on regulator box and job is done. |
