Steering column question on resto https://ausmini.com/forums/viewtopic.php?f=2&t=92964 |
Author: | fuzzy-hair-man [ Fri Jun 24, 2016 11:02 pm ] |
Post subject: | Re: Steering column question on resto |
Perhaps the inner column isn't right on the splines of the steering rack (you took the bolt out before putting it on?) otherwise the outer column can be pushed too far down, loosen of the steering column bracket under the dash and slide the column up, it is in the right place when the 'T' bolt on the inner column lines up and cancels the indicators. Is the steering wheel right down on the splines? |
Author: | 9YaTaH [ Sat Jun 25, 2016 9:08 am ] |
AUSMINI ELECTRONIC RUBBER STAMP sounds very dangerous to me i`d get a mini specialist to check it all over so much stuff to look at & if you miss one (seemingly) silly thing could mean disaster & pain please get an experienced mini mechanic onto it??? AUSMINI ELECTRONIC RUBBER STAMP |
Author: | shnitzee [ Sat Jun 25, 2016 11:15 am ] |
Thanks Fuzzy. ![]() The outer column was sitting too far down!! All good now. 9Y Will get it all checked out b4 it goes anywhere. Thank you. |
