https://ausmini.com/forums/
Help with 3 gauge cluster wiring
https://ausmini.com/forums/viewtopic.php?f=2&t=92963
Author:  shnitzee [ Fri Jun 24, 2016 7:06 pm ]
Post subject:  Help with 3 gauge cluster wiring
Hi all
Im installing the 3 pod cluster from the rust bucket into my 77 mini which came with a 2 pod cluster. I have 2 white wires for connection but i dont know what goes where!
Any advice appreciated.
Eiles
Author:  Dutchy1978 [ Fri Jun 24, 2016 9:17 pm ]
Post subject:  Re: Help with 3 gauge cluster wiring
The white wires are usually ignition/power supply to the cluster.
The below image is from a later model. Hope it helps.
I also have the Haynes version in the garage which I can take a photo of in the morning if you like.
Author:  shnitzee [ Fri Jun 24, 2016 9:43 pm ]
Thanks Dutchy.
That would be great.
Eiles
Author:  gtogreen1969 [ Fri Jun 24, 2016 9:56 pm ]
Don't the white wires run through the tacho?
12V from the ignition switch through the tacho then to the coil +.
Author:  Dutchy1978 [ Fri Jun 24, 2016 10:08 pm ]
What model is the 3 gauge cluster from?
Author:  Dutchy1978 [ Fri Jun 24, 2016 10:09 pm ]
Yes that and the cluster for the alternator charge light.
Author:  shnitzee [ Fri Jun 24, 2016 10:14 pm ]
The 3 pod came from a 1976 Leyland Mini S
Author:  Dutchy1978 [ Fri Jun 24, 2016 10:37 pm ]
So I found the following.
Pre 76 1275 GT (toggle type switches or rocker type)
& 76 onwards clubman & mini 1000 saloon with three gauge cluster.
See if these help.
Pre 76
76 onwards
Author:  shnitzee [ Fri Jun 24, 2016 11:13 pm ]
Thanks Dutchty.
We'll have a go in the morning.
Eiles
Author:  Convertible Mini [ Sat Jun 25, 2016 5:38 pm ]
There are two different types of Tachos on Australian Mini. Early one is the Loop type and later type senses from the neg side of coil.\
Author:  shnitzee [ Sun Jun 26, 2016 11:13 am ]
Thanks CM
Unfortunately, my brain has a lot of trouble when it comes to electrics so sorry if it's a bit of a 'duh' question but assuming the pod is a later style ('76) and I have two white wires on the harness, where exactly do I connect them?
Eiles
Author:  gtogreen1969 [ Sun Jun 26, 2016 1:43 pm ]
shnitzee wrote:
Thanks CM
Eiles
I had a 77 Leyland with a 3 gauge cluster. Here is a photo of the 2 white wires going to the tacho.
Author:  shnitzee [ Sun Jun 26, 2016 8:20 pm ]
Thanks Gtogree.
