It is currently Mon Jul 28, 2025 9:08 am
 Post subject: Mini wont rev at all
PostPosted: Sat Jun 25, 2016 12:20 pm
Hi guys,
I just got my mini and i know theres things wrong with it but just trying to identify what it is.
My mini will not rev at all now, I turn it on and it wont even rev at all and sounds like its starving of fuel. I have been told my mechanical fuel pump is leaking but is this the issue or would it be the carby?
Thanks in advance guys
 Post subject: Re: Mini wont rev at all
PostPosted: Sat Jun 25, 2016 1:01 pm
now it wont turn over.... think its the battery
PostPosted: Sat Jun 25, 2016 1:25 pm
When pushing accelerator and it hesitates to rev then it's fuel pressure or lack of. Could be that the ful pump is leaking and or diaphragm has carked it. Sort out fuel pump.
Battery nothing to do with revving, once it's going alternator provides the power unless alternator is also not charging too (your mini should have alternator warning light)
Lillee - 1969 Morris Mini K
PostPosted: Sat Jun 25, 2016 3:46 pm
probably the condensor,
i`ve actually no idea because the car is not here in front of me
so i`m guessing,,, simply because we don`t have enough information from you currently
to be able to give you an accurate diagnosis
but my guess is the condensor :-)
who`s next to have a guess? :-)
PostPosted: Sat Jun 25, 2016 3:55 pm
The fuel pump is def stuffed. Ill change that first or get an electronic one set up.
Thanks!!
PostPosted: Sat Jun 25, 2016 4:34 pm
Piss the points and condenser off and fit Electronic Ignition.
http://www.ebay.com.au/itm/301975641402 ... 1558.l2649
"Let us remove your "SHORTS"
PostPosted: Sat Jun 25, 2016 4:55 pm
i got no idea how to install one of these lol.... im such an amateur.
Anyone want to come help?!?!? Beer will be provided.
PostPosted: Sat Jun 25, 2016 5:15 pm
get it to a trustworthy mini mechanic to start with, get everything sorted out as is and then any upgrades you make will be from a known good starting point. Crazy to try and solve problems by changing things without actually knowing what's wrong to begin with....
it could just as easily be a blocked fuel filter, but you might jump and spend $$$ on a snazzy distributor to find nothing has changed
PostPosted: Sat Jun 25, 2016 5:21 pm
Cheers mate, but it def is the fuel pump ive seen it leak heaps. I cant even drive it yet, but will be taking it to Tovon Auto once its running properly and telling him to give me a to do list to see how much im up for
PostPosted: Sat Jun 25, 2016 7:21 pm
Carrum wore this strip when we played them in the Mornington Peninsular comp...
PostPosted: Sat Jun 25, 2016 7:34 pm
PostPosted: Sat Jun 25, 2016 7:39 pm
haha thats funny!!
PostPosted: Sun Jun 26, 2016 9:11 am
dawi03 wrote:
haha thats funny!!
Yes...great days, the NSW "rugby union thug" learned how to play Aussie Rules and beat them at their own game (....sometimes!)
Seriously tho, with little to go on...your question could go on for pages and your Mini still wouldn't rev...best idea might be to ask once again for someone or a group to come around and check a few things... :idea: :D
PostPosted: Sun Jun 26, 2016 6:35 pm
Do you have a dizzy without vac advance??
Jenk.
PostPosted: Sun Jun 26, 2016 8:59 pm
and one of the best ways to get help when you are new to Minis is to join a club :idea: :D
Users browsing this forum: winabbey and 75 guests
