It is currently Mon Jul 28, 2025 6:23 am
PostPosted: Fri Jun 24, 2016 7:06 pm
Hi all
Im installing the 3 pod cluster from the rust bucket into my 77 mini which came with a 2 pod cluster. I have 2 white wires for connection but i dont know what goes where!
Any advice appreciated.
Eiles
PostPosted: Fri Jun 24, 2016 9:17 pm
The white wires are usually ignition/power supply to the cluster.
The below image is from a later model. Hope it helps.
I also have the Haynes version in the garage which I can take a photo of in the morning if you like.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Fri Jun 24, 2016 9:43 pm
Thanks Dutchy.
That would be great.
Eiles
PostPosted: Fri Jun 24, 2016 9:56 pm
Don't the white wires run through the tacho?
12V from the ignition switch through the tacho then to the coil +.
PostPosted: Fri Jun 24, 2016 10:08 pm
What model is the 3 gauge cluster from?
1961 Morris mini
PostPosted: Fri Jun 24, 2016 10:09 pm
Yes that and the cluster for the alternator charge light.
1961 Morris mini
PostPosted: Fri Jun 24, 2016 10:14 pm
The 3 pod came from a 1976 Leyland Mini S
PostPosted: Fri Jun 24, 2016 10:37 pm
So I found the following.
Pre 76 1275 GT (toggle type switches or rocker type)
& 76 onwards clubman & mini 1000 saloon with three gauge cluster.
See if these help.
Pre 76
76 onwards
1961 Morris mini
PostPosted: Fri Jun 24, 2016 11:13 pm
Thanks Dutchty.
We'll have a go in the morning.
Eiles
PostPosted: Sat Jun 25, 2016 5:38 pm
There are two different types of Tachos on Australian Mini. Early one is the Loop type and later type senses from the neg side of coil.\
"Let us remove your "SHORTS"
PostPosted: Sun Jun 26, 2016 11:13 am
Thanks CM
Unfortunately, my brain has a lot of trouble when it comes to electrics so sorry if it's a bit of a 'duh' question but assuming the pod is a later style ('76) and I have two white wires on the harness, where exactly do I connect them?
Eiles
PostPosted: Sun Jun 26, 2016 1:43 pm
shnitzee wrote:
Thanks CM
Eiles
I had a 77 Leyland with a 3 gauge cluster. Here is a photo of the 2 white wires going to the tacho.
PostPosted: Sun Jun 26, 2016 8:20 pm
Thanks Gtogree.
