Can you modify non Cooper diff side covers for hardy units https://ausmini.com/forums/viewtopic.php?f=2&t=92950 |
Page 1 of 2 |
Author: | kiwiinwgtn [ Wed Jun 22, 2016 8:53 pm ] |
Post subject: | Can you modify non Cooper diff side covers for hardy units |
Hi I was wondering if you could modify non hardy spicer gearbox diff covers to fit the Hardie Spicer yokes I recall that some of the non cooper S covers where a solid casting which may have been from a OZ gearbox and therefore there is enough material to machine out. Has any one done this. Out of stock at mini spares and $$$ for what they are Ta Kiwiinwgtn |
Author: | timmy201 [ Wed Jun 22, 2016 9:10 pm ] |
Post subject: | Re: Can you modify non Cooper diff side covers for hardy un |
The one on the right here is thicker around the oil seal and can apparently be opened up for the Hardy Spicer couplings ![]() |
Author: | drmini in aust [ Wed Jun 22, 2016 9:46 pm ] |
Kiwi, The thick Oz ones machine out fine, but the S bushes are exxy (S tax). Send me a pm if you want a couple of covers, machined or not. |
Author: | simon k [ Thu Jun 23, 2016 12:27 pm ] |
timmy201 wrote: The one on the right here is thicker around the oil seal and can apparently be opened up for the Hardy Spicer couplings ![]() can someone remind me why the one on the right has the extra ear on it - I think I knew once but I've forgotten... |
Author: | timmy201 [ Thu Jun 23, 2016 12:31 pm ] |
Keeps the detent ball and spring in on rod change boxes |
Author: | kiwiinwgtn [ Thu Jun 23, 2016 6:01 pm ] |
drmini in aust wrote: Kiwi, The thick Oz ones machine out fine, but the S bushes are exxy (S tax). Send me a pm if you want a couple of covers, machined or not. Thanks Kevin. I am sure I have a pair somewhere and some automatic side covers I can rob the bushes from. I will get in touch if i get stuck. Cheers Kiwiinwgtn |
Author: | drmini in aust [ Thu Jun 23, 2016 7:42 pm ] |
All the torque is transmitted through there, if you turn it down 1/8" on diameter you are weakening it severely. The splines are bigger than on lesser Minis, that is why the outside diameter is increased. re the bushes- they wear, usually need replacement on a proper gearbox rebuild. If a sloppy fit, the seals leak sooner. I would fit new bushes, bugger the expense. ![]() Years ago there were Hardy Spicer style drive flanges sold to bolt onto rubber U/J output shafts. Dunno who made them, but I have seen several sets. |
Author: | kiwiinwgtn [ Thu Jun 23, 2016 7:47 pm ] |
drmini in aust wrote: All the torque is transmitted through there, if you turn it down 1/8" on diameter you are weakening it severely. The splines are bigger than on lesser Minis, that is why the outside diameter is increased. re the bushes- they wear, usually need replacement on a proper gearbox rebuild. If a sloppy fit, the seals leak sooner. I would fit new bushes, bugger the expense. ![]() the bushes are another out of stock item. So if i turn out the standard ones will an S seal fit into a non S side cover or do i need a special seal. |
Author: | drmini in aust [ Thu Jun 23, 2016 8:43 pm ] |
Both the bush and seal housing bores are enlarged by 0.125" diameter. Look like a S cover when done. ![]() S bushes are available, try Karcraft, Minisport Oz or Classic Motoring. I just bought 2. Edit need to bore bush to size after fitting. They are about 0.007" undersize. |
Author: | TheMiniMan [ Fri Jun 24, 2016 7:18 pm ] |
i have the conversion seals in stock if you just sort the bush part i also have the std seals & the "s" seals & lots of "s" side covers & millions of std side covers |
Author: | Bill B [ Sat Jun 25, 2016 8:39 pm ] |
kiwiinwgtn wrote: drmini in aust wrote: Kiwi, The thick Oz ones machine out fine, but the S bushes are exxy (S tax). Send me a pm if you want a couple of covers, machined or not. Thanks Kevin. I am sure I have a pair somewhere and some automatic side covers I can rob the bushes from. I will get in touch if i get stuck. Cheers Kiwiinwgtn If you have the automatic gearbox output covers for the diff, you don't need to rob the bushes from them - you have everything already to fit Hardy-Spicer universals as they used them too. Or have I missed something? Bill |
Author: | Kennomini [ Sat Jun 25, 2016 8:54 pm ] |
drmini in aust wrote: All the torque is transmitted through there, if you turn it down 1/8" on diameter you are weakening it severely. The splines are bigger than on lesser Minis, that is why the outside diameter is increased. re the bushes- they wear, usually need replacement on a proper gearbox rebuild. If a sloppy fit, the seals leak sooner. I would fit new bushes, bugger the expense. ![]() Years ago there were Hardy Spicer style drive flanges sold to bolt onto rubber U/J output shafts. Dunno who made them, but I have seen several sets. I'd love to see this kit as it sounds like what I've been thinking about making... |
Author: | drmini in aust [ Sat Jun 25, 2016 10:09 pm ] |
It was back in the 70s, John Smidt would probably remember them. (Edit) may have been KG Engineering? |
Author: | timmy201 [ Sun Jun 26, 2016 8:47 am ] |
Bill B wrote: kiwiinwgtn wrote: drmini in aust wrote: Kiwi, The thick Oz ones machine out fine, but the S bushes are exxy (S tax). Send me a pm if you want a couple of covers, machined or not. Thanks Kevin. I am sure I have a pair somewhere and some automatic side covers I can rob the bushes from. I will get in touch if i get stuck. Cheers Kiwiinwgtn If you have the automatic gearbox output covers for the diff, you don't need to rob the bushes from them - you have everything already to fit Hardy-Spicer universals as they used them too. Or have I missed something? Bill Bill, the automatic ones are completely different... ![]() ![]() |
