How to make custom Dash for a Clubbie https://ausmini.com/forums/viewtopic.php?f=2&t=92940 |
Author: | micool [ Tue Jun 21, 2016 2:31 pm ] |
Post subject: | How to make custom Dash for a Clubbie |
hey Guys trying to find any old topics with any how to or templates on how to make a custom dash. im looking for something plan and simply I can built to mount in my mini clubman race car to display some gauges. any help would be great |
Author: | fuzzy-hair-man [ Tue Jun 21, 2016 3:11 pm ] |
Post subject: | Re: How to make custom Dash for a Cubbie |
Here's a photo of the dash I made for my red Clubby: https://goo.gl/photos/WQkW4oGnAU3xjR8y6 The gauges are just the standard gauges, it's made out of one piece of folded 2mm? aluminium, I got it folded then took it home and slowly trimmed it down till it fitted correctly, the corners need slight bending outwards to allow the rest of the dash to go back far enough. It's very easy to remove there's 2 screws in the middle that used to hold the radio in I've used these to hold a 20cm? strip of aluminium that locks the dash in after that unplag some wires and the speedo and it comes out. |
Author: | RetroStyle [ Tue Jun 21, 2016 3:39 pm ] |
I'll be building this shortly for my clubbie: http://www.theminiforum.co.uk/forums/to ... -template/ Will also be making: http://www.theminiforum.co.uk/forums/to ... ker-board/ You need to be a registered user of that forum to access the file(s). No doubt a bit of trial and error to get to fit, but hey, I think it is worth a shot. |
Author: | Convertible Mini [ Wed Jun 22, 2016 6:32 am ] |
Mounting the gauges flat on the panel makes them awkward to see. They will need to be tilted up a little so they are facing you when you are at the wheel. No good them facing your chest and you need to duck to see them properly. |
Author: | micool [ Mon Jul 11, 2016 9:16 pm ] |
for some reson I cant registered as a user of that forum so cant access the file. |
Author: | gtogreen1969 [ Mon Jul 11, 2016 9:37 pm ] |
micool wrote: for some reson I cant registered as a user of that forum so cant access the file. I can email you the pdf templates if you want. |
Author: | micool [ Mon Jul 11, 2016 9:40 pm ] |
Thanks that would be great ill pm you my email |
Author: | gtogreen1969 [ Mon Jul 11, 2016 9:58 pm ] |
On its way. There are 2 PDF's. One dash takes up 7 pages alone. The other has 4 different styles on 4 pages. |
Author: | Jason Stevenson [ Thu Jan 07, 2021 9:24 pm ] |
gtogreen1969 wrote: micool wrote: for some reson I cant registered as a user of that forum so cant access the file. I can email you the pdf templates if you want. Sent from my SM-G960F using Tapatalk |
Author: | gtogreen1969 [ Thu Jan 07, 2021 10:01 pm ] |
Jason Stevenson wrote: gtogreen1969 wrote: micool wrote: for some reson I cant registered as a user of that forum so cant access the file. I can email you the pdf templates if you want. Sent from my SM-G960F using Tapatalk |
