https://ausmini.com/forums/
Front subframe fitting
https://ausmini.com/forums/viewtopic.php?f=2&t=92928
Author:  dimmo [ Sun Jun 19, 2016 12:46 pm ]
Post subject:  Front subframe fitting
Did all clubby's have the spacer on between
the top of the subframe tower and the body?
With the spacer my frame does not line up
at the front but would without it. I have a
78 clubby with a twin bolt subframe. TIA
Author:  drmini in aust [ Sun Jun 19, 2016 2:36 pm ]
Post subject:  Re: Front subframe fitting
Should have the spacers on.
If the front panel has ever been replaced with a new UK one (Clubby had a rubber mount subby over there), not only do you get this height problem but also a gap at the front. Solution is to fit 2 front UK teardrop rubber mounts.
(Edit) I found this on a Clubby van we owned.
Author:  dimmo [ Sun Jun 19, 2016 3:38 pm ]
Thanks for the info. I am not sure what has happened but yes i have had a lot of body work done
Author:  dimmo [ Sun Jun 26, 2016 2:39 pm ]
How much gap should there be between subframe and firewall above the steering rack? mine is 0.5 mm max should it be more?
Author:  simon k [ Sun Jun 26, 2016 3:13 pm ]
if it's the bit I'm thinking of (looking down the back of the motor towards the floor), then no, it should only be a small gap... mine catches washers when they drop down there
Author:  dimmo [ Sun Jun 26, 2016 3:52 pm ]
Thanks for the info Yay for Hay. that is about all there is so sounds ok just wanted to check before i tighten everything up
Author:  simon k [ Sun Jun 26, 2016 4:26 pm ]
no worries 848cc ;)
Author:  Morbo28 [ Fri Jul 01, 2016 1:55 pm ]
Grrrrrrrrrrr I feel your pain!!!
