Two questions... https://ausmini.com/forums/viewtopic.php?f=2&t=92914 |
Author: | Morbo28 [ Thu Jun 16, 2016 10:11 pm ] |
Post subject: | Two questions... |
1 - Tapping carby spacer Do you reckon I would be right to drill a 11/32 (9mm) hole (to tap 1/8 NPT thread to be specific) in the carb spacer shown in the two pics below? (I think the spacer is 14mm thick but might only be 11mm). I'm not sure what the spacer is made of so not sure how well it would work. It's not under boost, it's pre-supercharger. ![]() . ![]() 2 - Wiper wiring Here is a pic I found online of a wiper motor that is the same as I have. It has only three connections ("1", "2" and "E"). ![]() The wiring diagram and loom/harness appear to be for a different type of wiper motor, so I found a wiring diagram online below. I am assuming I just use one of the harness wires from "1" on the wiper motor to the wiper switch so the switch grounds the wire to turn it on. Is that right? ![]() |
Author: | simon k [ Thu Jun 16, 2016 10:28 pm ] |
Post subject: | Re: Two questions... |
1. that spacer is a fibrous insulating type material (phenolic?). It mightn't cut a clean thread. You can however drill it and araldite a tube into it. |
Author: | Morbo28 [ Thu Jun 16, 2016 10:41 pm ] |
simon k wrote: 1. that spacer is a fibrous insulating type material (phenolic?). It mightn't cut a clean thread. You can however drill it and araldite a tube into it. Aha! great idea thanks ![]() |
Author: | peterb [ Fri Jun 17, 2016 7:08 am ] |
Another idea would be instead of 1/8 fitting just use appropriate size pipe with thread tapped on it and use aradite as thread lock . I've done this as idle up on a/c kits using SU's. |
Author: | timmy201 [ Fri Jun 17, 2016 7:52 am ] |
You can buy them from minispares etc with a tapped hole http://www.minispares.com/product/Class ... |Back%20to |
Author: | Morbo28 [ Fri Jun 17, 2016 8:21 am ] |
timmy201 wrote: You can buy them from minispares etc with a tapped hole Thanks Timmy I saw those but those are much thinner spacers and the hole I need to tap is wider than the spacer http://www.minispares.com/product/Class ... |Back%20to ![]() |
Author: | Morbo28 [ Fri Jun 17, 2016 12:38 pm ] |
peterb wrote: Another idea would be instead of 1/8 fitting just use appropriate size pipe with thread tapped on it and use aradite as thread lock . I've done this as idle up on a/c kits using SU's. As in use araldite to hold a pre-tapped pipe? It does seem like a good idea to tap the thread in the pipe before I araldite it in place. I think that's the route I'll take. |
Author: | simon k [ Fri Jun 17, 2016 10:07 pm ] |
as for the wiper motor, yes, you're right - 1. should be the ignition 12v through a switch, and 2. should be either ignition or permanent 12v, depends whether you want the wipers to park or stay put when you turn the ignition off. They're usually ignition |
Author: | Morbo28 [ Sat Jun 18, 2016 3:11 am ] |
simon k wrote: ...1. should be the ignition 12v through a switch... I was thinking 1 should be ground through a switch?
Author: | simon k [ Sat Jun 18, 2016 12:00 pm ] |
Morbo28 wrote: simon k wrote: ...1. should be the ignition 12v through a switch... I was thinking 1 should be ground through a switch?hey yeah... go with that then, mini wiring diagram shows the same |
Author: | Morbo28 [ Sat Jun 18, 2016 12:52 pm ] |
Sweet as cheers for your help ![]() Sent from my Nexus 6P using Tapatalk |
Author: | s-c1293 [ Sun Jun 19, 2016 8:34 pm ] |
Hi Morbo, I have fitted 2 HP Performance/Link Automotive Supercharger kits, and have drilled and tapped this 1/2" thick spacer with 1/8 NPT for the brake boosters on both of them with out any problems. Just make sure you drill exactly in the centre as you only have around 2mm either side. I've had my one running like this for over 8 years now. Your kit looks very similar to theirs, where is yours from? |
Author: | Morbo28 [ Sun Jun 19, 2016 9:36 pm ] |
s-c1293 wrote: Hi Morbo, I have fitted 2 HP Performance/Link Automotive Supercharger kits, and have drilled and tapped this 1/2" thick spacer with 1/8 NPT for the brake boosters on both of them with out any problems. Just make sure you drill exactly in the centre as you only have around 2mm either side. I've had my one running like this for over 8 years now. Your kit looks very similar to theirs, where is yours from? Hi sc - my kit is also from Hans at HP ![]() I'd love to know any info or advice from your experience with the kits given the length of time you've lived with it...I'm running 8.9psi, with the engine specs built to suit the charger. Any tuning tips? How did your gearbox hold up? (I'm running std helical gears and drop gears on a 4 synchro rod change and Quaife diff). Did the kits meet your expectations? Any pics or a build thread? My build thread is here: viewtopic.php?f=3&t=86822 PM or reply here is welcome ![]() |
