https://ausmini.com/forums/
bike engine into mini
https://ausmini.com/forums/viewtopic.php?f=2&t=92913
Author:  mini09 [ Thu Jun 16, 2016 9:02 pm ]
Post subject:  bike engine into mini
hi all I'm in the process of modifying a Leyland mini and was wanting to no has anyone put a bike engine into a mini before . I'm not worried if I can register it or not just building the mini for fun thanx a lot .
Author:  miniman269 [ Thu Jun 16, 2016 9:56 pm ]
Post subject:  Re: bike engine into mini
Z cars in the UK have done heaps and they used to sell kits to do it but unfortunately they went belly up..
Sent from my SM-G900I using Tapatalk
Author:  1071 S [ Thu Jun 16, 2016 10:02 pm ]
There are lots if you look.. FWD..RWD . Multi speed sequential gearboxes are an advantage ... but not many bikes have reverse ..but there are options.
Cheers, Ian
Author:  Hobson [ Fri Jun 17, 2016 9:30 am ]
Depends on your budget.
http://www.vetech.co.uk/hayabusa/
Author:  fuzzy-hair-man [ Fri Jun 17, 2016 10:05 am ]
According to the mini magazine I was reading lately Z Cars is being revived by a Z cars owner and the original owner.
Author:  Maelgwn [ Fri Jun 17, 2016 11:06 am ]
Hey there Mini09,
I was looking into this a while back, as an option. still might do it one day :lol:
Both these kits use the Yamaha R1 (998cc) engine from the late 1999 -> Early 2003, after this the motor changes it size and doesn't fit under the bonnet. Both kits advise adding disc brake system as you are putting a 140-160 hp engine in the place of one giving 37 hp.
Try this kit, come with new sub-frame (advantage is a mechanical reverse driven from bike engine via special box) bike engine faces rearwards, carbs to the front, requires plumbing radiator to the other side.
http://www.pro-motive.co.uk
Try this kit as it has no or little modification to mini sub-frame, the kit bolt on bolt off (reverse is optional via a converted electric starter motor) bike engine faces forwards exhaust forward, allowing use of existing radiator.
http://www.lynxae.co.uk
Z-Cars is supposed to be getting back up and running but this has yet to be seen.
You could also try making your own Aussie custom sub-frame like the V-Tec and Suzmini guys!
Hope this helps.
Author:  mini09 [ Fri Jun 17, 2016 8:18 pm ]
Awesome thanks guys between the uncle and myself we have 12 minis 4 round nose the rest leyland. 1 has a turno starlet engine in it other has a swift engine. Looking at the 1275 block and bmw bike head for another .
Author:  ebbelsian01 [ Fri Jun 17, 2016 10:40 pm ]
There's one for sale on gumtree with an r1 and it's registered
Author:  Maelgwn [ Sat Jun 18, 2016 11:28 am ]
Hey Mini09
So that's why I can't find any mini's you have hogged them all :lol:
Author:  ten_sim [ Mon Jun 20, 2016 6:40 am ]
Vetech are pleased to announce that the price for the Vetech Hayabusa engine conversion kit base unit will start from £11,600 + VAT for the base unit. A donor Suzuki engine needs to be sourced by the customer (left-over engine housings and components can be re-sold after conversion).
Holy ****** moley!! :shock: :shock: :shock:
Just what the fook do you get for GBP12k+?? And you still have to source a donor engine!! :shock: :shock: :shock:
Author:  Miraz [ Mon Jun 20, 2016 7:15 am ]
They do seem to have taken the most expensive approach to doing this - they have designed a new set of engine casings that will accept most of the Hayabusa components, but incorporate a diff, reverse gear, etc along with all of the elements needed to package it up as a replacement for the A-series.
Even once you have sourced your donor engine, and paid for the kit then you will still need to do a full rebuild of the motor to replace the engine casings.
Author:  Hobson [ Mon Jun 20, 2016 9:16 am ]
But it does look nice, I was watching it for a while, then saw the price. maybe if I won the lotto, but then it would probs be a superfastminis.com kit.
Author:  mini09 [ Mon Jun 20, 2016 6:58 pm ]
hahaah nah havnt hogged them all just a few lol
