It is currently Mon Jul 28, 2025 5:36 pm
 Post subject: Welding, fuel tank ....
PostPosted: Sat Jun 18, 2016 4:21 pm
Hi all. I have a new rear valance to go on. What would people's recommendations be around having the fuel tank in place while this is done? The boot floor itself is fine.
I have a few parallel projects on the go where the tank needs to go back in, but at the same time id like the new panel to go on.
Patience is not one of my virtues.
Thanks in advance, Dave.
Sent from my SM-G900I using Tapatalk
"Evil will always triumph over good - because good is dumb"
1961 Mini 850 - sold 1997
1965 Mini Deluxe - sold 2013
1977 Mini LS - in build....
PostPosted: Sat Jun 18, 2016 4:40 pm
Id take tank out myself
PostPosted: Sat Jun 18, 2016 5:41 pm
Take out the tank. A lot safer. You may find some extra stuff to hit with rust convertor or touchup paint while you have it out.
PostPosted: Sat Jun 18, 2016 6:01 pm
Takes about half an hour to get the tank out. Takes years to get over burns.... assuming you're not killed.
PostPosted: Sat Jun 18, 2016 7:16 pm
It should be where fuel & sparks are involved :wink:
PostPosted: Sat Jun 18, 2016 7:28 pm
Thanks, the tank is already out. Will hold off putting it back in (i.e. will try this patience thing) until the valance is done. Thanks all for your input.
