It is currently Mon Jul 28, 2025 2:07 pm
PostPosted: Sun Jun 12, 2016 8:41 pm
Hi All
I want to install a handbrake warning light and a brake fail light on my 77 resto. I think I should be okay with the handbrake light install (thanks to info from the forum) but I'm a bit unsure how to go about wiring up the brake fail light. Any help would be muchly appreciated.
Thanks
Eiles
PostPosted: Sun Jun 12, 2016 9:30 pm
The factory used a relay that would switch the earth when the starter motor was engaged as well as the master cylinder pressure differential switch.
Here is a drawing I did when I recommissioned my dash lights last year.
Edit - Updated to a more user friendly copy.
PostPosted: Sun Jun 12, 2016 9:56 pm
Thanks gtogreen.
The car didn't come with these extra bits but I want to install them as functional upgrades.
Eiles
PostPosted: Sun Jun 12, 2016 10:23 pm
I wouldn't be using the scotch locks like the factory did.
Also the relay is a bit of an overkill just to check the dash bulb is not blown. Lots of things to go wrong and very messy under the bonnet.
You could just run a push button switch to earth for the bulb check.
PostPosted: Sun Jun 12, 2016 10:31 pm
I don't think the driver needs a light to tell him or her that the brakes have failed :shock:
just make sure the horn works , so you can advise others :oops:
PS please have insurance :D
PostPosted: Sun Jun 12, 2016 10:36 pm
The middle finger works wonders too
PostPosted: Sun Jun 12, 2016 10:58 pm
not when you are in the wrong :lol:
PostPosted: Mon Jun 13, 2016 5:42 am
Above circuit is correct but please DON'T USE SCOTCH LOCKS. That was one of the most Unprofessional thing Leyland Australia ever did on Minis.
"Let us remove your "SHORTS"
PostPosted: Mon Jun 13, 2016 8:36 pm
Ok.
Thanks for all the help and advice guys.
Eiles
Users browsing this forum: fuzzy-hair-man and 83 guests
