https://ausmini.com/forums/
How to instal brake fail light.
https://ausmini.com/forums/viewtopic.php?f=2&t=92878
Author:  shnitzee [ Sun Jun 12, 2016 8:41 pm ]
Post subject:  How to instal brake fail light.
Hi All
I want to install a handbrake warning light and a brake fail light on my 77 resto. I think I should be okay with the handbrake light install (thanks to info from the forum) but I'm a bit unsure how to go about wiring up the brake fail light. Any help would be muchly appreciated.
Thanks
Eiles
Author:  gtogreen1969 [ Sun Jun 12, 2016 9:30 pm ]
Post subject:  Re: How to instal brake fail light.
The factory used a relay that would switch the earth when the starter motor was engaged as well as the master cylinder pressure differential switch.
Here is a drawing I did when I recommissioned my dash lights last year.
Edit - Updated to a more user friendly copy.
Author:  shnitzee [ Sun Jun 12, 2016 9:56 pm ]
Thanks gtogreen.
The car didn't come with these extra bits but I want to install them as functional upgrades.
Eiles
Author:  gtogreen1969 [ Sun Jun 12, 2016 10:23 pm ]
I wouldn't be using the scotch locks like the factory did.
Also the relay is a bit of an overkill just to check the dash bulb is not blown. Lots of things to go wrong and very messy under the bonnet.
You could just run a push button switch to earth for the bulb check.
Author:  slacko [ Sun Jun 12, 2016 10:31 pm ]
I don't think the driver needs a light to tell him or her that the brakes have failed :shock:
just make sure the horn works , so you can advise others :oops:
PS please have insurance :D
Author:  Goldbrocade_62 [ Sun Jun 12, 2016 10:36 pm ]
The middle finger works wonders too
Author:  slacko [ Sun Jun 12, 2016 10:58 pm ]
not when you are in the wrong :lol:
Author:  Convertible Mini [ Mon Jun 13, 2016 5:42 am ]
Above circuit is correct but please DON'T USE SCOTCH LOCKS. That was one of the most Unprofessional thing Leyland Australia ever did on Minis.
Author:  shnitzee [ Mon Jun 13, 2016 8:36 pm ]
Ok.
Thanks for all the help and advice guys.
Eiles
