https://ausmini.com/forums/
Decoking?
https://ausmini.com/forums/viewtopic.php?f=2&t=92829
Author:  deluxe67 [ Mon Jun 06, 2016 4:01 pm ]
Post subject:  Decoking?
Hi,
My engine is in pieces because I'm installing a new camshaft (Doc will be pleased to hear it's the RE 282). The engine has only done 15000 km since full overhaul, do I remove the carbon from the piston crowns or leave alone. I'm in two minds, don't want loose crud to get between pistons and bores.
Also, should I take the bearing caps off for a looksee or again leave alone. Before dismantling the engine was perfectly healthy, 240 psi compression pressures and good oil pressure.
Thanks
Mikal
Author:  MiniBrad [ Mon Jun 06, 2016 4:07 pm ]
Post subject:  Re: Decoking?
I would leave the bearings alone & go get a can of carby clean & clean off the pistons & use an old rag to wipe off the debris.
Brad
Author:  drmini in aust [ Mon Jun 06, 2016 6:50 pm ]
What Brad said ^^
Smear some grease around the top of the bores then turn pistons past tdc, wipe grease off.
