https://ausmini.com/forums/
Removing rear subframe mount
https://ausmini.com/forums/viewtopic.php?f=2&t=92818
Author:  nefarious [ Sun Jun 05, 2016 2:00 pm ]
Post subject:  Removing rear subframe mount
Hi,
Dropped rear subframe from mini van today and went to remove subframe mounts. Discovered that the front mounts have what looks like a plug with 2 holes on end of the mount shaft and I have no idea how these can be remove to take off the mount.
The shaft the mount sits on simply spins when I use molys and I don't have adjustable grinder spanner (not that I think that would help).
Clearly I'm missing something, any help would be great ?? I can post picture if not clear in case this is model specific.
The back mounts were nuts and easy to remove.
Thanks in advance.
Author:  drmini in aust [ Sun Jun 05, 2016 2:33 pm ]
Post subject:  Re: Removing rear subframe mount
The round thing is the head of a `mount pin', ie. it is a glorified bolt.
There is a nut inside the subframe when you clear all the crud away.
Author:  Harley [ Sun Jun 05, 2016 7:35 pm ]
An angle grinder key / tool makes a useful holding devide for the trunnion pin when loosening the bolt.
:D
