HIF44 on 1100 https://ausmini.com/forums/viewtopic.php?f=2&t=92807 |
Author: | harryjday [ Thu Jun 02, 2016 10:08 pm ] |
Post subject: | HIF44 on 1100 |
Hey Guys, Just put my HIF44 on my 1100 mini however its running super rich as it was originally set up for a 1360. Just wondering if anyone has put an hif44 on an 1100 before and if so what needle do you suggest? Thanks |
Author: | PDJ [ Thu Jun 02, 2016 10:12 pm ] |
Post subject: | Re: HIF44 on 1100 |
Is it a standard 1100? Have you adjusted the mixture? |
Author: | harryjday [ Thu Jun 02, 2016 10:13 pm ] |
Yeah just a standard 1100, so an hif44 is probably too big in reality. And yeah wound the mixture all the way in and still rich |
Author: | leonrjohnson [ Fri Jun 03, 2016 4:20 am ] |
I have a HIF44 on my 970 cc Cooper S engine. BDL is the needle I started out with but was a bit lean at the top end, BBW fitted ,good over all. This is what I have now. BCE seems too rich at bottom end BDL seems too lean at top end BCF too rich mid to top end. I did this using an AFR meter up the exhaust pipe, and a fair bit of road testing. http://www.mintylamb.co.uk/suneedle/ This is a useful site to compare needles. HIF44 has 0.0100 jet. |
Author: | harryjday [ Fri Jun 03, 2016 8:34 am ] |
Awesome thanks mate! Might try out the BBW or BCE, the 970 cooper s head has bigger ports than a standard 1100 yeah? So might end up a similar needle |
Author: | leonrjohnson [ Fri Jun 03, 2016 10:46 am ] |
970 has huge ports and valves, and i rev it to 8000, but on the 1100 I might try the BDL to begin with.I think you will find the BCE is too rich for you. |
Author: | harryjday [ Fri Jun 03, 2016 10:53 am ] |
Ok I will give that a go! Thanks for that ![]() Looking at putting a 12G295 on it at some point so will have to bump the needle up a bit then anyway |
Author: | benjamin [ Fri Jun 03, 2016 8:19 pm ] |
harryjday wrote: Yeah just a standard 1100, so an hif44 is probably too big in reality. And yeah wound the mixture all the way in and still rich winding in is richer , out is leaner. |
