Minimatic auxiliary heater/radiator https://ausmini.com/forums/viewtopic.php?f=2&t=92795 |
Author: | simonw [ Wed Jun 01, 2016 1:08 pm ] |
Post subject: | Minimatic auxiliary heater/radiator |
This poor girl is a bit worse for wear .. ![]() ![]() ![]() Anybody have one lying around ? If not I will go about remaking some of the panels.. Question though .. That colour ( the olive silver) is that the original colour ? An undercoat or plating ? Many thanks gents S Sent from my iPhone using Tapatalk |
Author: | drmini in aust [ Wed Jun 01, 2016 2:55 pm ] |
Post subject: | Re: Minimatic auxiliary heater/radiator |
They were all painted black. Not sure if plated underneath. |
Author: | Mokesta [ Wed Jun 01, 2016 11:45 pm ] |
I have one. The top mounting tabs have broken off but the rest appears fine, like not rusty but certainly not restored. M |
Author: | goodie [ Thu Jun 02, 2016 5:03 am ] |
I have one here , i can get you a pic . It appears from the discussion on it that it is the earlier type, has 3 legs . ![]() |
Author: | John Smidt [ Thu Jun 02, 2016 9:31 am ] |
As Dr Kev mentioned, they were all painted black. they were never plated. It appears to me that this has been chemically cleaned, and if I am correct that would account for the colour |
Author: | drmini in aust [ Thu Jun 02, 2016 9:37 am ] |
There were 2 types- Early ones had 3 bolts, later ones had 2 bolts at top and a V rubber (like a Moke bonnet hinge one) at the bottom, which sat in a |_| shaped bolt. |
Author: | simonw [ Thu Jun 02, 2016 9:50 am ] |
Yes John that may be the reason as I caustic bath all of my bits before restoring them ... This silvery tone comes up often ![]() On the backing plate for example. Sent from my iPhone using Tapatalk |
Author: | simonw [ Thu Jun 02, 2016 9:52 am ] |
The one I have is the later one then Doc. Would that have been correct for a late 68 ? Sent from my iPhone using Tapatalk |
Author: | drmini in aust [ Thu Jun 02, 2016 10:13 am ] |
Not sure when that came in. Mine is 3/70 and has it, so did a 69 one that I had. |
Author: | John Smidt [ Thu Jun 02, 2016 4:48 pm ] |
simonw wrote: The one I have is the later one then Doc. Would that have been correct for a late 68 ? Sent from my iPhone using Tapatalk Yes it is the correct one for 1968 |
Author: | Goldbrocade_62 [ Fri Jun 03, 2016 7:38 pm ] |
http://www.ebay.com.au/itm/Morris-Mini- ... Sw9eVXUSDh |
Author: | jubblies [ Fri Jun 03, 2016 9:21 pm ] |
Goldbrocade_62 wrote: http://www.ebay.com.au/itm/Morris-Mini-850-Deluxe-Heater-Box-/222139776186?hash=item33b88ffcba:g:KkMAAOSw9eVXUSDh This is the early one. It will require you to drill a hole on the inner panel and remove the bracket. |
Author: | Goldbrocade_62 [ Fri Jun 03, 2016 9:44 pm ] |
jubblies wrote: Goldbrocade_62 wrote: http://www.ebay.com.au/itm/Morris-Mini-850-Deluxe-Heater-Box-/222139776186?hash=item33b88ffcba:g:KkMAAOSw9eVXUSDh This is the early one. It will require you to drill a hole on the inner panel and remove the bracket. It is could be modded if needed or make one from 2 |
