https://ausmini.com/forums/
Bench testing an alternator
https://ausmini.com/forums/viewtopic.php?f=2&t=92750
Author:  shnitzee [ Fri May 27, 2016 8:50 pm ]
Post subject:  Bench testing an alternator
Hi All
I have this alternator that came with my Rust Bucket. I would like to keep it as a spare for my 77 Resto (if it still works ok). How do I check it out of the car?
Any help is greatly appreciated.
Eiles
Author:  goodie [ Fri May 27, 2016 9:19 pm ]
Post subject:  Re: Bench testing an alternator
Any alternators that i have wanted checked i take them to an Auto Electrician that's not far from me, they have a machine that they can put them on and run them up and check them , they usually only charge me $5 to check them .
It looks like a clubbie alternator , do you know anyone with a mini that is running the same type ?, you could put it on their car and check the voltage with a multi-meter :idea: .
Author:  shnitzee [ Fri May 27, 2016 11:41 pm ]
Thanks Goodie.
I'll try the sparkie.
Eiles
Author:  Convertible Mini [ Mon May 30, 2016 7:55 am ]
I have a Machine "Test Bench" for testing Alternators. It is much quicker than fitting it to a car and I can do tests on it that you can not perform on a Car. Like loading the crap out of the Alternator to see what it's maximum output is. Charging $5 to test is fair as this machine is worth over $10,000. to buy .
Author:  shnitzee [ Mon May 30, 2016 8:27 pm ]
$5 is very reasonable for peace of mind.
Thanks CM
Author:  BBY755 [ Mon May 30, 2016 8:34 pm ]
I would like a couple of generators tested here in Sydney......pretty sure it'll be a lot more than $5.....
Anyone recommend anyone who could test them in the north of Sydney?
