dipstick oil seal location https://ausmini.com/forums/viewtopic.php?f=2&t=92747 |
Author: | 71morris [ Fri May 27, 2016 1:49 pm ] |
Post subject: | dipstick oil seal location |
Dipstick oil seal are there two seals or only one or is the oil seal placed on top of block or from underneath |
Author: | TheMiniMan [ Fri May 27, 2016 2:13 pm ] |
Post subject: | Re: dipstick oil seal location |
there`s generally 2 types of dipstick, one is the early std mini type,flat metal with a little rubber boot that slips up to the round flat section on the stick,,, & goes with the plastic type tube the other is the "S" type, looks like it`s 2 bits of steel folded & takes a tapered type seal fitted to the stick,,, & takes the metal tube hope that helps edit,,, sorry there is a 3rd type, Late APlus type, & it doesn`t have a tube in the block, it is similar to the "S" type but just simply fits into the countersunk hole in the block |
Author: | wild_willy [ Fri May 27, 2016 2:32 pm ] |
TheMiniMan wrote: there`s generally 2 types of dipstick, one is the early std mini type,flat metal with a little rubber boot that slips up to the round flat section on the stick,,, & goes with the plastic type tube the other is the "S" type, looks like it`s 2 bits of steel folded & takes a tapered type seal fitted to the stick,,, & takes the metal tube hope that helps edit,,, sorry there is a 3rd type, Late APlus type, & it doesn`t have a tube in the block, it is similar to the "S" type but just simply fits into the countersunk hole in the block PLUS there is the very early 850 dipstick with no tube just goes straight in the block. |
Author: | 71morris [ Fri May 27, 2016 2:52 pm ] |
ok I just want to confirm the actual tubes plastic non S or steel Cooper S is there an Oring fitted to the metal tube as well inside the block or under the rolled lip on the outside top of block even for the plastic tubes |
Author: | sitnlo62 [ Fri May 27, 2016 7:56 pm ] |
71morris wrote: ok I just want to confirm the actual tubes plastic non S or steel Cooper S is there an Oring fitted to the metal tube as well inside the block or under the rolled lip on the outside top of block even for the plastic tubes I think Matt is having a senior moment. The Plastic Dip stick tube type is definitely the Later type fitted on. Mini K. There is no seal of any type fitted between the block and tube on either the metal or plastic type tube. I normally Glue in the plastic type with epoxy, they all seem to become loose with age, The Metal tube is normally a nice tight fit even after being removed and replaced a few times. Dave |
Author: | 71morris [ Fri May 27, 2016 8:12 pm ] |
ok, can a few people with the knowledge, confirm if mk2 is plastic or the steel type for MK2 cooper S |
Author: | sitnlo62 [ Fri May 27, 2016 8:34 pm ] |
71morris wrote: ok, can a few people with the knowledge, confirm if mk2 is plastic or the steel type for MK2 cooper S Metal type tube for MK2 Cooper S |
Author: | Bill B [ Fri May 27, 2016 9:40 pm ] |
As sitnlo62 says... Ditto for my MkII S - steel tube. My 1969 mini K has a plastic tube. |
