https://ausmini.com/forums/
12G940 head.
https://ausmini.com/forums/viewtopic.php?f=2&t=92741
Author:  70K1100 [ Wed May 25, 2016 9:39 pm ]
Post subject:  12G940 head.
I came across a 940 head whilst cleaning up my workshop. The head has 35mm inlet valves and hardened valve seats in exhaust valves. However I looked at the ports and they measured out at approximately 30mm. I looked at my small valve 940 head and the ports are about the same size. Will the bigger valve head still flow enough to handle a 266ss cam and Vizardised twin HS2 carbs. I read that the Morris 1300GT produces about 70hp new and 74ftlb. Would this head flow enough to produce similar?
Author:  drmini in aust [ Wed May 25, 2016 10:25 pm ]
Post subject:  Re: 12G940 head.
Yes it will be fine. Mk2 S head just had the 35.6mm inlets and stronger springs. Ports were much the same.
The major flow restriction is at the valves on a 940 head.
Author:  70K1100 [ Thu May 26, 2016 12:28 am ]
Thanks Dr Mini. It will save a few dollars not having to get another head built.
Author:  71morris [ Thu May 26, 2016 10:44 am ]
If you believe you have a standard S head
where do you by brand new valves?
Is UK usually the best EN steel?
Do you usually measure the valve with vernier calipers?
Author:  winabbey [ Thu May 26, 2016 1:04 pm ]
The usual Mini spares places will have them - viewtopic.php?f=41&t=83593
Here's MKO as an example - http://minikingdomonline.com.au/product ... ts/page/3/
Author:  71morris [ Thu May 26, 2016 3:22 pm ]
Is there any difference in quality from minispares UK
with the cooper S EN steel exhaust or inlet valves
compared to sales in Australia you would buy the new AEG valves I believe
Author:  simon k [ Fri May 27, 2016 11:03 pm ]
I have these in my car, I bought them when Lindsay was still running the business and he recommended them, saying that's what he uses in his race engines
http://www.minisplus.com.au/old-shop/pr ... d-race-ser
the exhaust version is on there somewhere
Author:  simon k [ Fri May 27, 2016 11:06 pm ]
this might be it - http://www.minisplus.com.au/old-shop/pr ... -exclusive
