9F/Xe/Y engine identification https://ausmini.com/forums/viewtopic.php?f=2&t=92657 |
Author: | 71morris [ Mon May 16, 2016 9:42 pm ] |
Post subject: | 9F/Xe/Y engine identification |
If you have a 9F/Xe/Y engine, no vehicle or compliance plate how can you tell if it was from a 69mk1/2 or a mk2 cooper S, or a Leyland mini GT, the three registers the numbers do not exactly run in ascending order |
Author: | drmini in aust [ Mon May 16, 2016 9:45 pm ] |
Post subject: | Re: 9F/Xe/Y engine identification |
Post the engine number here or check the Cooper S list on here. |
Author: | 71morris [ Mon May 16, 2016 9:50 pm ] |
I realise you have the register but the three vehicles I mentioned, do not appear to have the engine number stamped on compliance plates |
Author: | gtogreen1969 [ Mon May 16, 2016 10:15 pm ] |
Because the compliance plates don't show engine numbers the only way to know for sure is the Passports to service, purchase documents, or one owner cars. They did jump around a lot but you should be able to work out the year. 51000 to 54000 could be 1969. 53000 to 56000 could be 1970. 55000 to 56000 could be 1971. |
Author: | low n blown [ Tue May 17, 2016 6:57 pm ] |
71morris wrote: If you have a 9F/Xe/Y engine, no vehicle or compliance plate how can you tell if it was from a 69mk1/2 or a mk2 cooper S, or a Leyland mini GT, the three registers the numbers do not exactly run in ascending order 69 will often be a MK1 block with Mk2 numbers |
