It is currently Sun Jul 27, 2025 11:41 pm
PostPosted: Mon May 16, 2016 9:42 pm
If you have a 9F/Xe/Y engine,
no vehicle or compliance plate
how can you tell if it was from a 69mk1/2
or a mk2 cooper S,
or a Leyland mini GT,
the three registers the numbers do not exactly run in ascending order
PostPosted: Mon May 16, 2016 9:45 pm
Post the engine number here or check the Cooper S list on here.
PostPosted: Mon May 16, 2016 9:50 pm
I realise you have the register
but the three vehicles I mentioned, do not appear to have the engine number stamped on compliance plates
PostPosted: Mon May 16, 2016 10:15 pm
Because the compliance plates don't show engine numbers the only way to know for sure is the Passports to service, purchase documents, or one owner cars.
They did jump around a lot but you should be able to work out the year.
51000 to 54000 could be 1969.
53000 to 56000 could be 1970.
55000 to 56000 could be 1971.
PostPosted: Tue May 17, 2016 6:57 pm
or a mk2 cooper S,
69 will often be a MK1 block with Mk2 numbers
1962 Mini Speed sports sedan
