https://ausmini.com/forums/
what is the best camshaft lube to use in the A series
https://ausmini.com/forums/viewtopic.php?f=2&t=92604
Author:  71morris [ Wed May 11, 2016 12:13 pm ]
Post subject:  what is the best camshaft lube to use in the A series
In Australia due to shipping,
what is the best/suitable camshaft lube to use in the A series mini engine
and where to buy?
can not see any listed on Any of the Australian mini business websites?
Author:  drmini in aust [ Wed May 11, 2016 3:10 pm ]
Post subject:  Re: what is the best camshaft lube to use in the A series
Karcraft sells mpz cam lube, around $16.50 a tube.
I just use Castrol LMM molygrease. It is less likely to drip off if engine is stored for any time.
Author:  TheMiniMan [ Thu May 12, 2016 8:25 am ]
mix half/half of molly grease & STP, best Sticky Tacky Poop you can get
we`ve used it on lifters & cams since the noah designed the Arc :-)
Author:  Freddo [ Thu May 12, 2016 9:40 am ]
I used Nulon L90 with no problems in our motors
http://www.nulon.com.au/products/Specia ... ant/#intro
Author:  Bill B [ Thu May 12, 2016 7:06 pm ]
What cam did Noah's ark use?
And does Minispares still sell them?
PS
Thoughts to you and family about your father. He will never go far away from you.
PPS Thanks for the formula too.
Bill
Author:  TheMiniMan [ Fri May 13, 2016 7:59 am ]
Hits like button ;)
