It is currently Tue Jul 29, 2025 12:25 am
PostPosted: Thu May 05, 2016 8:18 pm
I have a 1964 mini been trying fix my brakes I just cant seem to do it.
tried putting two new brake cylinders on one is leaking and the other is not bleeding up. I am after someone to come around and do the job as it cant be driven and sort them out will pay cash money for the job to be done!
I am in Adelaide located in Greenwith.
thanks Ralph.
PostPosted: Thu May 05, 2016 8:34 pm
If you don't get a specific response from someone local, have you tried Googling mobile brake services? I had a professional guy come to my garage to fit a power brake booster, make up some pipes and bleed the whole system on a Mini. That was in Melbourne - no idea in Adelaide.
PostPosted: Fri May 06, 2016 3:55 pm
Yeah was hoping for a enthusiast as they some times know better than the expert and get the job done better.
PostPosted: Sat May 07, 2016 9:41 pm
Hey, if you were around the corner then no probs but I am up In the hills. Are you talking front or rear? And the one leaking, is it from the inlet or the piston?
PostPosted: Mon May 09, 2016 8:28 pm
I can help if you still need it. I have restored a few over the years and completely rebuilt the brakes on mine recently. I am in the northern suburbs.
TOO MANY MINIS AND NOT ENOUGH TIME
