Washer bottle bracket https://ausmini.com/forums/viewtopic.php?f=2&t=92558 |
Page 1 of 2 |
Author: | OnSafari [ Wed May 04, 2016 3:01 pm ] |
Post subject: | Washer bottle bracket |
Could somebody please let me know the correct fasterners to hold the windscreen washer bottle retaining bracket to the firewall. During the repaint we inadvertently filled the holes. I assume self tappers? Thanks in advance. |
Author: | OnSafari [ Thu May 05, 2016 7:15 am ] |
Post subject: | Re: Washer bottle bracket |
Thanks |
Author: | Bubbacluby [ Thu May 05, 2016 7:29 pm ] |
I know that picture ![]() |
Author: | gtogreen1969 [ Thu May 05, 2016 7:35 pm ] |
It was the easiest one to borrow. |
Author: | Bubbacluby [ Thu May 05, 2016 7:39 pm ] |
yeah all good, I dont mind, if it helped someone im happy |
Author: | wild_willy [ Fri May 06, 2016 2:04 pm ] |
Washer bottle brackets fixed with 2 metal thread screws spring washers and nuts. Holes are too big for self tappers. Parts list gives screw as PMZ0308 which is zinc plated pan head Number 10 x 1/2inch. |
Author: | gtogreen1969 [ Fri May 06, 2016 3:44 pm ] |
wild_willy wrote: Washer bottle brackets fixed with 2 metal thread screws spring washers and nuts. Holes are too big for self tappers. Parts list gives screw as PMZ0308 which is zinc plated pan head Number 10 x 1/2inch. My 69 S has small holes and self tappers. No visible scratch marks around the holes from any washers or nuts. I cut up an 850 shell a few months back and it had self tappers. I remember having to get the impact screwdriver onto it because I wanted to keep the washer bottle bracket. Maybe the CKD cars had the screws and nuts. The UK cars have a screw, 2 washers and a nut listed as the fastener. http://www.somerfordmini.co.uk/eshop/in ... page&id=82 |
Author: | Stuwey [ Fri May 06, 2016 3:55 pm ] |
My 68 Deluxe was definitely 2 self tappers. |
Author: | deluxe67 [ Fri May 06, 2016 3:59 pm ] |
Ditto my 67 Deluxe |
Author: | Flute [ Fri May 06, 2016 4:47 pm ] |
Maybe they did it two different ways. My '68 S has two self tappers. ![]() ![]() ![]() ![]() |
Author: | kath20 [ Fri May 06, 2016 4:51 pm ] |
I went to a mini 850 that was a wreck but very origional, the owner gave me the washer bottle bracket & it had never been removed. It was held on with two self tappers.Cheers. |
Author: | rodmac [ Fri May 06, 2016 5:47 pm ] |
66 deluxe and 67 mk1 S both 2 x self tappers Cheers Rod |
Author: | Bubbacluby [ Fri May 06, 2016 5:50 pm ] |
wild_willy wrote: Washer bottle brackets fixed with 2 metal thread screws spring washers and nuts. Holes are too big for self tappers. Parts list gives screw as PMZ0308 which is zinc plated pan head Number 10 x 1/2inch. I am fairly certain the 62 850 I wrecked earlier this year had this. |
Author: | DavidE [ Fri May 06, 2016 6:50 pm ] |
Bubbacluby wrote: wild_willy wrote: Washer bottle brackets fixed with 2 metal thread screws spring washers and nuts. Holes are too big for self tappers. Parts list gives screw as PMZ0308 which is zinc plated pan head Number 10 x 1/2inch. I am fairly certain the 62 850 I wrecked earlier this year had this. I have some considerable stocks of the original self tappers used in all the vehicles I have been associated with. |
