Flushing an unknown condition mini engine https://ausmini.com/forums/viewtopic.php?f=2&t=92511 |
Author: | 71morris [ Thu Apr 28, 2016 10:21 pm ] |
Post subject: | Flushing an unknown condition mini engine |
Whats best to use to flush an engine in unknown condition, it is not driveable/unknown/ it could be seized? Is diesel or CRC/WD40 possible to use in a mini engine? |
Author: | drmini in aust [ Fri Apr 29, 2016 7:41 am ] |
Post subject: | Re: Flushing an unknown condition mini engine |
First check the oil, if it looks black & sludgy, change it and the filter first. Next, pull the spark plugs out, check if engine can turn over by hand. If so, squirt a little engine oil into each cylinder. If not, I would pull the head off for a look. If standing for more than 6 months I would prime the oil pump before trying to start it: Remove oil pipe banjo bolt from block, squirt motor oil into the block until hole is full, with 4th gear engaged, push car backwards for 2 revolutions of the fan, squirt more oil in, refit bolt but leave 1 turn loose to let air out. Select neutral. Crank engine for no more than 20 secs with plugs out. If oil flows out around the bolt, good news- you have oil pressure, tighten it up. If it just gives 1 burp (what oil you put in) and no oil flow, I am sorry but the oil pickup strainer is plugged with sludge. Engine strip time.... ![]() |
Author: | 71morris [ Fri Apr 29, 2016 3:49 pm ] |
No oil is in engine or gearbox/sump. It has been sitting for more than six months, it could have been years, the engine flush I have looked at, appears to want the engine running and run but as stated it has been sitting for a long time. I believe I need to lubricate bores and rings as you stated, I have heard of people using diesel to flush, but unsure. I might try oil with millilitres of engine flush, I have not heard of anything else/product to clear sludge from gearbox pickup/strainer, this is why I suggested diesel, but unsure if diesel will damage bearings and seals in gearbox or piston rings/bores in the engine? |
Author: | drmini in aust [ Fri Apr 29, 2016 4:17 pm ] |
Forget engine flush, fill with 20w50 oil then follow what I said above. |
Author: | MiniBrad [ Fri Apr 29, 2016 5:18 pm ] |
I've had good results using ATF in the spark plug holes & letting sit for a week for so after Dr's advice has been carried out to help free up stuck pistons but if it's to that point a rebuild will more than likely be needed. Brad |
